wet 4th cylinder? why?!?!
Old Mar 23, 2004 | 06:43 PM
4ornia's Avatar
Default wet 4th cylinder? why?!?!
alright here it is. i have a 95 coupe with a 00' b16a2 swap. i look down into the 4th cylinder (the one farthest away from the distributor), and it was wet a little, all the other cylinders were more dry and look the same. could it be oil or fuel? is this normal or should i worry about something? should it smoke under heave acceleration? recently rebuilt motor (4K miles) and running full synthetic oil.
Old Mar 23, 2004 | 06:47 PM
mmuller's Avatar
Mad Scientist
Default Re: wet 4th cylinder? why?!?! (bootyloc)
If you are not burning oil and your plugs look good, then i wouldnt worry about it.
You might have a leaky injector, run some injector cleaner.
fyi the cyl. farthest from the dizzy is #1
Old Mar 24, 2004 | 11:05 AM
4ornia's Avatar
Default Re: wet 4th cylinder? why?!?! (mmuller)
i am burning a little bit of oil but not accessive about a quart 1 to 1.5 k but thats hard miles thoughit smokes alittle when i down shift or get on it hard
Old Mar 24, 2004 | 11:12 AM
MightyMouseTech's Avatar
First off, that is cylinder #1, not 4.
Next, where EXACTLY are you seeing the oil? In the sparkplug hole? On top of the piston after removing the plug? Where?
The_Honda_Guy
27
Jul 5, 2011 07:11 PM
mach3lude
Sep 22, 2010 06:14 AM
patrick4588
Dec 21, 2007 03:48 PM
Reza^
May 22, 2007 10:24 AM
LSCivic
Sep 12, 2001 01:34 PM
