Any ECU's(USDM) that don't look for CKF??
Old Mar 25, 2004 | 06:43 AM
jdmkevin's Avatar
Default Any ECU's(USDM) that don't look for CKF??
I need to pass emissions and am thinking about plugging in a non-vtec ECU that doesn't look for CKF cause I don't want to change the oil pump. TN's emissions test only looks for stored codes. I just want to plug up 2nd O2 and EGR valve and whatever else just to pass. Let me know what ECU's you think will do it. THanks!!
Old Mar 25, 2004 | 09:29 AM
EE_Chris's Avatar
Default Re: Any ECU's(USDM) that don't look for CKF?? (jdmkevin)
The CKF sensor is specific to OBD2 and has nothing to do with whether the engine has VTEC or not.
OBD1 ECU's do not look for the CKF sensor....however, going down this route will not help as now the TN emmisions test center can't hook up an OBD2 scantool to check for codes.
Old Mar 25, 2004 | 10:46 AM
Katman's Avatar
Default Re: Any ECU's(USDM) that don't look for CKF?? (EE_Chris)
Yeah, so you're pretty much ***'d out in the US OBD2 ecu department.
On the other hand you can use a JDM OBD2 ecu, but the US OBD2 scanning tools might not be able to communicate to the JDM OBD2 ecu.
dc4teggiehatch
Sep 10, 2021 02:55 PM
lostwun1
May 2, 2018 08:26 PM
crxhybrid85
Mar 5, 2005 06:45 AM
blackflag188
May 21, 2004 07:58 AM
