OEM Timing Belt B16A2
Old Mar 21, 2004 | 11:28 AM
civikdude's Avatar
Default OEM Timing Belt B16A2
What brand is the OEM timing belt on a B16A2? I have two options, the Goodyear is roughly $20 less than the other, so of course wouldn't mind going with the less expensive of the two. Do you think buying the Goodyear belt would be OK?
Timing Belt
A5000-64254
In Stock Japan $59.62 55.96
Timing Belt
A5000-64254
In Stock Goodyear $59.62 $35.10
Old Mar 21, 2004 | 11:32 AM
AngryTroll's Avatar
Default Re: OEM Timing Belt B16A2 (civikdude)
The last time I checked, the OEM belt is cheaper online than the aftermarket belts are local.
Old Mar 21, 2004 | 12:25 PM
civikdude's Avatar
Default Re: OEM Timing Belt B16A2 (AngryTroll)
Yeah, I found these prices on http://www.overnightautoparts.com. $35 for a timing belt seems reasonable. Thoughts on a Goodyear brand belt? Or should I go with the "Japan" brand for $56?
Old Mar 21, 2004 | 03:30 PM
AngryTroll's Avatar
I bought a timing belt for a '99 Civic SI from Hparts.com for $41.56. {OEM}
Old Mar 21, 2004 | 03:37 PM
Clutchmasta55
Guest
Posts: n/a
The Goodyear brand would be ok to use. As for quality and performance an Oem belt would be the better choice and worth an extra $20 after all it was designed for your ride.
Old Mar 21, 2004 | 05:18 PM
JDM PRO's Avatar
just buy an oem belt to have some peace of mind
ALLxMotor DA
Sep 6, 2008 06:10 AM
killacam661
Aug 30, 2007 04:34 PM
Steak84SS
May 26, 2004 04:18 PM
Gong Show
Jan 27, 2003 11:35 AM
TrueZen
Dec 17, 2002 03:46 PM
