trouble removing oil pan...
Old Mar 24, 2004 | 11:25 AM
J337_UNIT's Avatar
Default trouble removing oil pan...
i got off all of the bolts except the ones covered by the flywheel cover.. my motor is a b18b, now i tried removing those bolts on the flywheel cover, the larger ones that are attached to the tranny and those are siezed big time, i put all my weight onto those and cannot remove them even with the breaker bar and im a 170lb guy. so now my other option i thought of was to use a dremel and cut away a small piece of the flywheel cover that covers those last 2 oil pan bolts.. i just wanted to run this past some members here and see what they thought before i do it. let me know.. tia
Old Mar 24, 2004 | 12:29 PM
leeit2me's Avatar
Default Re: trouble removing oil pan... (J337_UNIT)
what size of a breaker bar you using? 3/8" or 1/2" or a 3/4". I would suggest using a 1/2" and slipping longer piece of a pipe on the breaker bar for more leverage.(spray some liquid wrench on the bolts). Or if you know a buddy that has a air impact gun that will always do the trick.
Old Mar 24, 2004 | 01:19 PM
Kal's Avatar
Kal
Default Re: trouble removing oil pan... (leeit2me)
yep impact gun would do awesome
Old Mar 24, 2004 | 05:18 PM
J337_UNIT's Avatar
Default Re: trouble removing oil pan... (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">yep impact gun would do awesome</TD></TR></TABLE>
ill see if i have access to one.. but i doubt i will.. i really think i could just shave the metal that covers those bolts away with a dremel.
BoltonGSR
Nov 5, 2006 09:43 PM
zexifiedlude
Mar 14, 2006 07:05 AM
shbrown
Jan 28, 2006 03:46 PM
Hatch It
Jun 7, 2005 02:08 PM
AF-b16a1
Aug 2, 2004 09:53 PM
