b16a2 spun rod bearing!
Old May 28, 2004 | 09:44 AM
h1coupe's Avatar
Default b16a2 spun rod bearing!
hei guys i can get a complete swap for my car for a pretty good price, there is everything in it, engine, tranny, harness, ecu, axles, shiftlinkage, everything i need i will get! but the engine has a spun bearing, the car it was in flipped and then engine ran while the car was upside down, i have two other parts motors with almost everything except the blocks so do i have to worry about something else about the motor or am i safe if i just buy new bearings, or is there anything else that can happen to the motor from running upside down(i donīt know for how long, but the motor ran but had a knock when it was stripped from the car).
Old May 28, 2004 | 10:45 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: b16a2 spun rod bearing! (h1coupe)
Sure, the Crank could be messed up if it was ran too long and started to chew it up
Old May 28, 2004 | 03:18 PM
h1coupe's Avatar
but i have 2other cranks so i should be fine right!
Old May 28, 2004 | 04:20 PM
notstock93's Avatar
Default Re: (h1coupe)
you have two other B16 cranks? Go for it, IF you can get it for REALLY cheap. A rebuild isnt going to cost too much if its already torn down. Check to make sure the sleeves arent cracked or scored very badly, and everything is on the up and up.
Old May 29, 2004 | 07:49 AM
h1coupe's Avatar
itÂīs not torn down it was just recently pulled from the car!
and yes i have 2b16 parts motors!
and thanks alot for the replies guys helped out alot
Old May 29, 2004 | 07:52 AM
ExospeedAMcrx's Avatar
if you are going to replace the crank as well, then that would be fine. but dont forget to check the mains as well if its in good condition.
LudeLooker
Jun 21, 2013 03:08 PM
blinx9900
11
May 16, 2007 01:52 PM
standinghollow
Sep 20, 2006 11:13 AM
Naturally Aspirated
35
Oct 8, 2004 04:57 PM
Spade
Jul 25, 2002 08:10 AM
