Nubish question...why buy LSD???
Old May 26, 2004 | 09:43 AM
unknown0001's Avatar
Default Nubish question...why buy LSD???
Hey guys, I've always had a small understanding of what LSD is but can somebody clarify how it benefits the car??
I've seen a lot of people jump allover eachother to buy a SOHC LSD for their D-series..but what's the hype about it?? Does it provide better traction?
thanks
Old May 26, 2004 | 10:05 AM
Kal's Avatar
Kal
Default Re: Nubish question...why buy LSD??? (Mr.RHTuner)
yes it does. If your car is modified, it helps put the power down a lot better than an open differential does. Plus, when you launch it prevents one wheel spinning quicker than the other it spins both wheels instead of just one.
it also helps handling by transferring power to the slipping wheel. hence the name, Limited Slip Differential.
there are many choices for a LSD, the choice is yours
Old May 26, 2004 | 10:08 AM
RevenantAE's Avatar
An LSD helps ensure that power goes to the wheels with traction. It prevents one wheel from spinning uselessly while the other just sits there. If conditions are right, you may still madly spin both tires, but the point is that you are doing a better job of getting power to the wheels, and thus to the ground.
Old May 26, 2004 | 12:07 PM
Default Re: Nubish question...why buy LSD??? (RevenantAE)
ok, thanks guys. I fully understand now
brendan427
Transmission & Drivetrain
10
Sep 7, 2012 01:58 AM
NebulousX
Apr 26, 2008 06:28 PM
spurge
11
Aug 9, 2007 06:20 PM
eg686
Jun 7, 2005 04:47 AM
J-Unit31
Jul 2, 2004 06:36 PM
