would having the wrong ecu cause vtec to not engage?
Old May 27, 2004 | 02:27 PM
typeeg's Avatar
Default would having the wrong ecu cause vtec to not engage?
tia
Old May 27, 2004 | 03:04 PM
typeeg's Avatar
Default Re: would having the wrong ecu cause vtec to not engage? (StockEG9)
the setup is a b18c1 swapped into an EF civic. I am not sure what ecu it is running so could it be that since the b18c utlizes the butterflies that using the wrong ecu is causing the vtec to not engage?
Old May 27, 2004 | 04:28 PM
typeeg's Avatar
no one?
Old May 27, 2004 | 05:41 PM
dfoxengr's Avatar
well if you have a non-vtec ecu then it wont work.
Old May 27, 2004 | 06:40 PM
typeeg's Avatar
Default Re: would having the wrong ecu cause vtec to not engage? (hybridvteceg)
yeah I figured that much! lol
but what about a p28 on a b18c1? Would that cause it not to engage?
Old May 27, 2004 | 08:45 PM
anothersickhatch's Avatar
a p28 is a single over head cam vtec computer. it will engage, but not nearly as strong as a p72 or a dual cam vtec ecu. correct me if im wrong though.
yes, having the wrong ecu for the motor you have will cause vtec to not engage, or engage just slightly. had the same problem till i changed to a chipped ecu.
momodc221
Feb 14, 2012 08:27 AM
jdmkidd23
Jan 8, 2009 03:08 PM
Whiteintegra
Jul 14, 2006 05:16 PM
volcomstoned
May 24, 2006 10:06 PM
