ls head on b20 block
Old May 23, 2004 | 11:00 PM
jdmsijdm's Avatar
Default ls head on b20 block
ok right now i have a complete LS head, ive taken it apart and it appears to be in good shape. A friend of mine is in need of a new motor for his car and isnt wanting to spend a whole lot. I told him i will put the motor together for him and put it in his car and if he likes it, he will buy it. If not, we will pull it out and his shitty smokey oilburning sohc will go back in. But here is what i plan for the set up. Stock ls head, stock block, but which block? Will this head bolt right onto the b20 block with no probs? or should i just stick with the LS bottom end. Like i said we are trying to go the cheap route with this. Probably all OEM parts. Oh yeah we plan to use a b16 hydro tranny with this set up. We still need some parts too so let me know if you guys have any parts you might have that could help with this set up. As of now i have an LS head, b16 intake mani, and any parts we can use from his current motor, its a 93 si hatch. what you guys think. At this point im leaning at the b20 block/ls head combo. help us out here, and we plan to document it with pics as soon as the ball gets rolling. Help me out here guys.
Old May 24, 2004 | 12:29 AM
jdmsijdm's Avatar
Default Re: ls head on b20 block (jdm wannabe)
are you sure? i thought i read somewhere that an LS head flows better than a b20 head. So you are saying that the LS and b20 heads are exactly the same?
Old May 24, 2004 | 06:56 AM
non-VTEC's Avatar
Default Re: ls head on b20 block (jdmsijdm)
the B20 and B18B cylinder heads are the same. no diffrence in flow or anything like that.
Old May 25, 2004 | 07:59 PM
StorminMatt's Avatar
Default Re: ls head on b20 block (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the B20 and B18B cylinder heads are the same. no diffrence in flow or anything like that.
But only the B18B nead is the same. The B18A head is inferior.
Old May 26, 2004 | 01:20 AM
jdmsijdm's Avatar
ok so ive decided to go with a b20 block for this project. i am going to use the LS head i have, its from a b18b. and we are using a b16 hydro tranny. Do you guys know what mounts/axles/ecu/harness we need? its going in a 93 civic si vtec hatch.
Old May 26, 2004 | 07:39 AM
highcomp's Avatar
Default Re: (jdmsijdm)
wow your going to need alot first off you will need a hydeo to cable convrsion kit for a 93 si is hydro you can get this at hasport. Next rear mount braket from 94 teg ecu form 94 teg distributor from 94 teg axles from 91-93 teg stock teg mounts will bolt up. Its not going to be as cheap as you think.
Old May 26, 2004 | 08:32 AM
mmuller's Avatar
Mad Scientist
Default Re: (highcomp)
he does not need a cable to hydro conv. since the car already comes with a hydro tranny.
Old May 26, 2004 | 12:51 PM
jdmsijdm's Avatar
ok so i can use the mounts that are already in the civic? and yeah its already a hydro equipped car so i know i dont need the conversion kit.
Damills
Mar 10, 2009 11:32 AM
sickb16b
Jul 25, 2005 07:08 AM
VSM3point5genDC4
Sep 23, 2003 07:56 AM
eRACING
Sep 18, 2003 03:16 PM
JasonNagra
Mar 31, 2002 03:14 PM
