rpm matching while shifting/driving
Old May 9, 2008 | 10:27 AM
pootie.teng's Avatar
Default rpm matching while shifting/driving
since i have a lighten flywheel and i don't shift like i'm racing everyday. I was just wondering if anyone else matches rpms before shifting into the next gear. my lighten fly drops the rpms pretty quick while driving so i made it a habit of matching my rpms before in throw it to the next gear. is there a need to do so anyways.
for example i usaully shift around 2.5-3K rpm but when i change gears it drops to like 1-1.5K so the rpm has to jump up around 500-1krpm's or so to get back to speed. i usually tap the gas (barely) in between shifts to keep the rpms in the right revs before i release the clutch.
i think this will save my trans and my motor life. what do you guys think...
Old May 9, 2008 | 10:50 AM
02 accord's Avatar
Default Re: rpm matching while shifting/driving (pootie.teng)
Shift faster
Old May 9, 2008 | 11:30 AM
rally25rs's Avatar
i rev match my downshifts during normal everyday driving. keeps me in practice. I've got a stock flywheel on everything at the moment, so I don't have to do it on upshifts.
IMO, it helps the synchro life if you rev match and double clutch anyway, so why not?
Old May 9, 2008 | 11:35 AM
Default Re: rpm matching while shifting/driving (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Shift faster </TD></TR></TABLE>
hahaha...naw...don't drive like a mad man everyday and i don't try to shift fast. i just driving normal...
Old May 9, 2008 | 12:17 PM
badboyr66's Avatar
I tend to match as well... just getting into the habit before the other motor goes in. Day to day driving I try and be nice to my tranny
Old May 9, 2008 | 08:23 PM
361 accord's Avatar
lightweight flywheels arent exactly for everyday driving
but yes revmatching all the time saves ur clutch!
Old May 10, 2008 | 07:30 AM
KevinT707's Avatar
I'd say just shift a little faster there buddy! I have a 7lb flywheel and I don't have to blip the throttle on upshifts; only downshifts, obviously.
Old May 10, 2008 | 03:04 PM
ltrkstr2k's Avatar
Default Re: (KevinT707)
i do it sometimes on upshifts but always on downshifts. it just feels better lmao.
Old May 10, 2008 | 03:27 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pootie.teng &raquo;</TD></TR><TR><TD CLASS="quote">for example i usaully shift around 2.5-3K rpm but when i change gears it drops to like 1-1.5K so the rpm has to jump up around 500-1krpm's or so to get back to speed. i usually tap the gas (barely) in between shifts to keep the rpms in the right revs before i release the clutch.
You do know that it takes as much, if not more fuel to get the car up to speed shifting that low than it would if you shifted a little higher in the powerband, right? Fuel consumption is more dependent on throttle position than it is revs. Try shifting a little higher to keep it from bogging.
I've never had any drivability issues with my 9lb flywheel and I never blip the throttle on an upshift.
MikhailBjornson
Transmission & Drivetrain
Jan 30, 2017 10:14 PM
Ryan559
Mar 19, 2013 12:14 PM
suken19
Mar 21, 2006 10:00 AM
Kyles ej1
34
Nov 2, 2004 09:47 PM
1fastGSR
Jan 29, 2002 01:36 PM
