CRX with ITR brake swap problem !!!
Old May 30, 2007 | 06:37 PM
mantiod's Avatar
Default CRX with ITR brake swap problem !!!
I swaped my stock crx front calipers with itr calipers and I can not seem to get a hard pedal. I've bled the brakes several times and there is no sign of air.
So my question is will I have to swap the master cylinder to the itr also.
Any help is appreciated Thanx.
Old May 31, 2007 | 12:34 AM
nb0's Avatar
nb0
Default Re: CRX with ITR brake swap problem !!! (mantiod)
I think you need a 1" master cylinder.
Old May 31, 2007 | 07:47 AM
FalkenSiR's Avatar
Default Re: CRX with ITR brake swap problem !!! (nb0)
Do you have the ITR proportioning valve?
Old May 31, 2007 | 09:48 AM
dr_latino999's Avatar
Default Re: CRX with ITR brake swap problem !!! (FalkenSiR)
Your master cylinder is too small.
Old Jun 1, 2007 | 03:37 PM
mantiod's Avatar
Default Re: CRX with ITR brake swap problem !!! (dr_latino999)
No the rest of the brakes are all stock
Old Jun 1, 2007 | 03:39 PM
mantiod's Avatar
Any Idea what other masters would fit.
Old Jun 2, 2007 | 02:38 PM
Sliced Beard's Avatar
you can use a 15/16 brake master cylinder and brake booster out of a 4-door civic EX or out of an acura integra and you will be just fine and they can be had for 50 bux or less from a junk yard.
Old Jun 2, 2007 | 06:45 PM
CRX T-Si's Avatar
Just the 90-91 4 DR EX civic MS and things will be good.
Make sure you got the 40/40 PV if you have the Rear Discs.
You cannot use the Integra one unless you mod one of the lines so don't bother.
Chance EG
Mar 16, 2018 10:39 AM
joprez
May 7, 2013 02:54 PM
hunan beef
May 9, 2011 03:43 PM
abusedhusband
Suspension & Brakes
May 30, 2007 10:28 AM
Lxi_R
Jun 17, 2001 07:57 AM
