need assist about ITR intake arm
i'm going to install an ITR intake arm on my B16 but it has only one hole for the breather hose. where will i put the secondary O2 sensor? do i have to punch a new hole? if so, what can i use?
thanks for the reply, but i was talking about the intake tube. i need to know where i could hook-up the intake sensor cause there is only one hole and it's already taken up by the breather hose from the valve head cover.
You probably don't have a choice but to drill a small hole to accompany the IAT (intake air temperature) sensor. It shouldn't be hard, and the fitment should be easy enough, as long as you don't drill the hole too big. The IAT sensor comes with its own grommet (or whatever you call it...gasket?) to help hold it firmly in place in the tube.
EDIT: Just make the sure the wire can reach, and on a side note....the resale value on the tube won't be the same...but that's a given duh.
[Modified by IN VTEC, 10:29 AM 4/22/2002]
[Modified by Nos4R2, 3:07 PM 4/22/2002]
Diversion
Jul 21, 2009 11:57 AM
jwaked
Aug 12, 2004 12:02 AM
