swap wont start iam stumped.
Old Apr 20, 2002 | 05:53 AM
rainforest's Avatar
Default swap wont start iam stumped.
here are the symtoms. and variables
1. its a z6 block with a y8 head in a crx dual point inj to multi-point
2. I had to re wire the dist from external coil back to internal.
3. i have spark so the dist seems to be working
4. timing marks all on.
5. ground cable is bad but i earth grounded it so it cranks.
6. i have fuel.
7. all injectors are getting 12volts to them.
8. the vtc is hot wired to the feilds straight to the vtec controler portion of it.
it you could think of anything else it would help.
Old Apr 20, 2002 | 09:55 AM
Allstar's Avatar
New User
Default Re: swap wont start iam stumped. (rainforest)
I had the same problem with one of my cars. My engine had spark, fuel and compression but it wouldn't start. Turns out the distributor was bad but it still supplied spark??? I but a different dist in and it started right up.
Old Apr 20, 2002 | 12:50 PM
Kamin's Avatar
i would swap the dist. or double check it to make sure its wired right.
just my .02
turbotegy10
May 13, 2011 06:53 AM
mark11017
May 16, 2009 07:17 AM
unrealgtx
Sep 20, 2007 08:16 PM
GreenEHDriver
Sep 1, 2006 07:31 AM
