Crower Stroker kit? What rod/stroke ratio?
Old Apr 20, 2002 | 02:00 PM
InfamousRS's Avatar
Default Crower Stroker kit? What rod/stroke ratio?
I was looking through Crowers website, and I cam accross their stroker kits. You can get them with cranks with a 92mm or 95mm stroke. What rod/stroke ratio would that be?
Old Apr 20, 2002 | 06:45 PM
boosted3g's Avatar
Default Re: Crower Stroker kit? What rod/stroke ratio? (BLK94RS)
I figured it out a long time ago with a LS motor and the 95mm stroke and if i remember correctly i came up wtih 1.32
Old Apr 20, 2002 | 10:20 PM
InfamousRS's Avatar
Default Re: Crower Stroker kit? What rod/stroke ratio? (boosted3g)
THATS HORRIBLE!
Old Apr 20, 2002 | 11:08 PM
simple4012's Avatar
New User
mad torque.......for like 5900 miles
Old Apr 20, 2002 | 11:17 PM
rainforest's Avatar
Default Re: Crower Stroker kit? What rod/stroke ratio? (simple4012)
how big are the rods with that kit????
Old Apr 21, 2002 | 03:01 AM
riceboy's Avatar
Default Re: Crower Stroker kit? What rod/stroke ratio? (rainforest)
stroker kits arent worth the money, but a turbo
Old Apr 21, 2002 | 09:10 AM
boosted3g's Avatar
Default Re: Crower Stroker kit? What rod/stroke ratio? (riceboy)
keep in mind i fugured this with using off the shelf pistons and having custom rods made. I think if you buy the whole kit from Crower they use a custom piston where the pin is moved up and the threfore the rod could be made slightly longer. The R/S ratio will still suck but that wouldnt refrain me from getting othe kit, however the price will.
Old Apr 21, 2002 | 11:28 AM
H22Si's Avatar
Or you could weld a 1" plate to the top of the block, then have the block sleeved. You could have a 1.8 ratio if you wanted to!
Old Apr 21, 2002 | 11:30 AM
teg92's Avatar
Default Re: Crower Stroker kit? What rod/stroke ratio? (H22Si)
If you are serious about performance than what H22Si is recommending is not that far fetched!!
Listerofsmeg
Sep 7, 2015 12:16 PM
Junaid K
Oct 23, 2011 10:23 PM
BoostnEK6206
May 21, 2007 12:00 PM
mdrews187
Dec 11, 2001 11:37 AM
