H22A/Civic axle ?'s
Old Apr 24, 2002 | 04:25 PM
Mikey3000's Avatar
Default H22A/Civic axle ?'s
i finally got my H22 in my 92 civic cx. i'm using the hasport mount kit along with a 93 accord int. shaft and 93 integra axles. the problem is: the axles are angled. from the int. shaft, the axles angle toward the back of the car into the hub. my question is: how does this affect the life of the axles? am i going to be breaking axles up the yin yang?
Old Apr 24, 2002 | 06:16 PM
riceboy's Avatar
Default Re: H22A/Civic axle ?'s (Boss Hogg)
they are supposed to sit like that, and you shouldnt have a problem with breaking axles if the motor is stock, might want to invest in a Z10 though.
Old Apr 24, 2002 | 06:25 PM
Holeshot's Avatar
We've had more people break axles with the Hasport kit as opposed to the HCP because of the angle. You can either raise your car some, to relieve the angle or get the Driveshaft Shop stage one setup. We have had good success with those and they are only $300 for a set.
Old Apr 24, 2002 | 06:26 PM
Jared's Avatar
Default Re: H22A/Civic axle ?'s (Holeshot)
I have an 89 Si with a turbo B18C1 and a welded diff and I'm having somewhat of a hard time keeping axles in it, any suggestions? BTW, daily driven.
Old Apr 24, 2002 | 08:38 PM
SCsol's Avatar
Default Re: H22A/Civic axle ?'s (Jared)
get a LSD burn the weilded dif thats why you spilting out alxes
Old Apr 25, 2002 | 04:01 AM
Jared's Avatar
Default Re: H22A/Civic axle ?'s (lowsol)
If I got rid of the diff, i wouldnt get a lsd, i'd get a spool which would be the same effect.
Old Apr 25, 2002 | 04:43 AM
Mikey3000's Avatar
Default Re: H22A/Civic axle ?'s (riceboy)
a Z10 what?
Old Apr 25, 2002 | 06:52 AM
Spade's Avatar
http://www.driveshaftshop.com
Ayeso
25
Jul 31, 2008 09:54 PM
crazybeanery0
Jun 10, 2007 08:46 AM
RedK
Jun 30, 2005 05:34 AM
Mikey3000
Apr 24, 2002 05:04 PM
