B18a intake manifold on a B16a-Will it work?
Old Apr 25, 2002 | 05:34 PM
pelotudo's Avatar
Default GSR intake manifold on a B16a-Will it work?
Can a GSR intake manifold bolt straight on to a B16a, and what kind of gains from it?
jB
[Modified by PeloTudo, 9:51 PM 4/25/2002]
Old Apr 25, 2002 | 05:37 PM
riceboy's Avatar
Default Re: GSR intake manifold on a B16a-Will it work? (PeloTudo)
with a little modification, but WHY?
Old Apr 25, 2002 | 05:51 PM
pelotudo's Avatar
Default Re: GSR intake manifold on a B16a-Will it work? (riceboy)
Might be albe to get one for pretty cheap...if it adds cheap HP; I'm all about it
What kind of gains can I expect from it though?
Old Apr 25, 2002 | 06:26 PM
Katman's Avatar
....if any gains. you'lll see an increase in torque because of the design of the snail shell manifold.....but thats about it. I wouldnt do it if i were you tho...and if you do still wanna do it, you'd be better off with a GSR head as well. You'll make a little more compression w/a gsr head.
You might run into lower clearance issues with a GSR manifold's bottom half + B16A block, because the B16A's deck is 7mm less than that of a B18C block. Hoses might get in the way and prevent easy installation.
I have a friend (Bombino) that tried a GSR head+manifold on B16A block, didnt run too well.....he doan likey.
Old Apr 25, 2002 | 06:36 PM
jArceo's Avatar
Default Re: GSR intake manifold on a B16a-Will it work? (Katman)
u can get a gsr intake manifold from almost everyone with a gsr
most go the skunk2 way becuz gsr intake manifold just plain
newbie1
Jan 8, 2008 10:28 AM
AP1_man
Feb 24, 2007 11:58 PM
markpa2
May 18, 2004 06:13 AM
mike34655
Aug 24, 2003 06:37 PM
SpoonMan
Dec 17, 2002 01:17 PM
