Highest compression on pump gas in a hot climate.
Old Apr 25, 2002 | 10:00 AM
X2BOARD's Avatar
Default Highest compression on pump gas in a hot climate.
Building up a GSR motor and was not exactly sure on some compression #'s.
Assuming an otherwise stock engine, stock ignition, stock injectors, f pump, etc... a good header and intake:
What would be the highest safe compression that could be run on pump gas 92-93 octane w/o adding any type of ocatne booster ?
Would 12.0:1 be possible ? Or would 11.5:1 be where I should stay ? The Celica GT-S runs 11.5:1 stock w/o a problem...sooo.... what's up with 12.0:1 ? Or higher ?
Would running a small (50-75 shot) of nitrous be unadvisable at 12.0:1 as well (fuel management and spark would be upgraded by this time) ?
Thanks, I'm X2 and I'm in sunny Florida.... jealous ?
Old Apr 25, 2002 | 10:16 AM
B19CivicHB's Avatar
Default Re: Highest compression on pump gas in a hot climate. (X2BOARD)
ill be running 12.5:1 in a JDM GSR engine. 94 octane pump gas, timing retarded 3 degrees.
Old Apr 25, 2002 | 10:54 AM
X2BOARD's Avatar
Default Re: Highest compression on pump gas in a hot climate. (B18CivicHB)
Have you run this high of a compression before ?
Old Apr 25, 2002 | 01:39 PM
B19CivicHB's Avatar
nope, but have done TONS of research. I plan on getting a V-AFC and a FPR then im gunna get some dyno time to tune it. It should be fine un-tuned, and a beast tuned.
Old Apr 25, 2002 | 05:40 PM
riceboy's Avatar
12.5 can be done in texas, and we never get below 100 degrees here in the summer
benjamenenglish
28
Mar 10, 2010 05:25 AM
civic_66
23
Oct 25, 2008 05:22 PM
black0hatch
Jun 6, 2008 06:38 AM
jdmb16ef8
Aug 19, 2007 03:10 PM
Spoold_R
May 12, 2002 06:44 PM
