speedometer is not working...
Old Apr 23, 2002 | 04:17 PM
KekeK-18's Avatar
Default speedometer is not working...
I've check the Speed sensor connectors and they are in place. What else could it be besides bad sensor or bad connection? Any thoughts on this? BTW, its a 92 si with a gsr motor.
Old Apr 23, 2002 | 06:06 PM
EGh22aEG's Avatar
Default Re: speedometer is not working... (KekeK-18)
did it ever work or did u just do the swap cause when i swapped my motor into my car they said i had to change the speedometer cause it was cable and my engine is elecrtirc or digital or something
Old Apr 23, 2002 | 07:19 PM
All Motor EG's Avatar
check fuse
Old Apr 24, 2002 | 02:00 AM
D16Z6racing's Avatar
Default Re: speedometer is not working... (All Motor EG)
Do you have any type of aftermarket gauge faces? Sometimes they slide down and put weight on the needle holding it down. Happened to my temp. gauge.
Old Apr 24, 2002 | 02:38 AM
rainforest's Avatar
Default Re: speedometer is not working... (buster13)
check for continuity on the wire. also check the back of the gadge cluster.
Old Apr 24, 2002 | 03:59 AM
KekeK-18's Avatar
Default Re: speedometer is not working... (rainforest)
it was working fine before and it just give up. All the fuse are ok.....may it be a bad sensor??
Old Apr 24, 2002 | 09:25 PM
HaUTSaauce's Avatar
New User
i just had to replace my VSS a few weeks ago when i was having the same problem
Old Apr 25, 2002 | 09:29 PM
manveer's Avatar
I'm guessing you have a mechanical speedometer since it's a 92 Si. Based on that - have you checked the mechanical part of it? The cable could have slipped out of the back of the gauge cluster or slipped out of the transmission. Check it - on my CRX the cable came out of the gauge cluster and when I put it back everything was fine. I don't believe the VSS has anything to do with the speedometer gauge - isn't the speedometer fully mechanical?
Old Apr 25, 2002 | 10:53 PM
KekeK-18's Avatar
Default Re: speedometer is not working... (manveer)
Thanks guys, I found out one of the pin in the plug of the speed sensor was missing...the middle one, Its all good now.
Old Apr 26, 2002 | 01:18 AM
Bombino's Avatar
New User
92+ civic comes w/ electronic speedo, not mechanical.
Old Apr 26, 2002 | 01:42 AM
Kamin's Avatar
Default Re: speedometer is not working... (Bombino)
doublecheck alllllll the VSS stuff
i FINALLY got mine fixed. every time i hit vtec my spedo would jump and flutter to about 120mph (no matter what speed) one of the connectors got seperated a little too far and there was a continuity issue. crimped it back down, no problems
Old Apr 27, 2002 | 12:33 AM
manveer's Avatar
Sorry...that was just my assumption since I have an 89 CRX w/ mechanical and 92 is close to that year. That was the reason for my semi-disclaimer at the beginning of my post.
Tank_EM2
Honda Civic (2001 - 2005)
Nov 6, 2015 04:17 PM
96civic808
May 18, 2010 08:16 AM
joethejoeman
Jan 18, 2007 04:50 PM
HmgLauj69
Aug 4, 2005 02:29 PM
Tuan
Apr 27, 2005 11:19 AM
