Restarting problem
Old Apr 25, 2002 | 06:25 AM
1hottEG6's Avatar
Default Restarting problem
Got a b20 w/b16 head. I will be running the car for any amount of time 1hr-4hrs. When i shut it off and try and restart the car will not restart until it cools down. i.e ( when i try to restart the engine. it will crank, but not turn over) soo.... I do know its getting fuel cause the pump is turning on. However i dunno if its getting spark. I think it could be the coil or ignitor , but the coil is only like 2 months old so. I have no idea, any help would be great. My question is basically has anyone had a problem like this..? thanks
Old Apr 25, 2002 | 06:54 AM
Spade's Avatar
Default Re: Restarting problem (B20eg)
Not sure but, could it be the tempurature rating of the spark plugs????
Old Apr 25, 2002 | 08:50 AM
1hottEG6's Avatar
Default Re: Restarting problem (Spade)
so how do i fix that problem
*spark plugs are fairly new ???thanks
Old Apr 25, 2002 | 11:48 AM
Perfectionist's Avatar
First, check for spark. If you've got spark, I would suspect a 'hot soak restart' problem. The TW sensor gets flakey and tells the ECU the engine is cold which results in flooding. The TW sensor is not the same one that feeds the dash temp gauge. Usually, it's the one right underneath the distributor.
Old Apr 25, 2002 | 11:52 AM
92TypeR's Avatar
FSAE
Default Re: Restarting problem (Perfectionist)
my car has been doing the same thing....before and after i did the swap. I always thought it had to do with the fuel pump.
I just leave my car idleing if i know i'm gonna be leaving quick...
Old Apr 25, 2002 | 11:57 AM
1hottEG6's Avatar
So what do i do with the TW sensor like how do i check if its no good..?
and hate to sound like an idiot but what is a "tw" sensor.
Old Apr 25, 2002 | 08:01 PM
Chiovnidca's Avatar
"TW" is what Honda used to call the "ECT" sensor. (Engine coolant temperature.) You can check the resistance of the sensor and compare it against the spec for the temperature. I can't recall the numbers off the top of my head but they should be in the service manual. I'm thinking about 150 ohm at normal operating temperature. x0,000 when cold. (But I could be wrong.)
grandtheftlunchbox
Oct 12, 2008 05:51 PM
jdsmooth
Mar 7, 2008 04:59 PM
BlueRex1020
Jan 3, 2008 07:32 AM
A.E Motoring
Aug 16, 2006 07:04 PM
b16hatch
Feb 19, 2003 05:47 AM
