jrsc b20vtec?
Old Apr 23, 2002 | 03:57 PM
spankaveli's Avatar
Default jrsc b20vtec?
is this feasible? i wouldn't run over the stock 6psi. MAYBE a 30 shot for the track. that would be after good fuel and ignition upgrades. could the b20 pistons handle this? also i'd get the JRSC for the GSR, correct?
thanks and please give any insight in this.
thanks
spanky
Old Apr 23, 2002 | 04:10 PM
done's Avatar
Default Re: jrsc b20vtec? (spankaveli)
what internals will you use?
Old Apr 23, 2002 | 04:13 PM
spankaveli's Avatar
stock internals. i dont have the money to build the block right now. i probably won't even mess w/ the 30 shot. ive been told by a very knowledgable source that b20 crank is balanced to 8k from honda, so it should be OK for stock revlimit. probably. if i stay w/ crvtec n/a i'll get skunk2 stage 2 cams and portflow inner and ITR outters, if i go w/ jrsc ill get the ITR exhaust cam only.
Old Apr 23, 2002 | 08:01 PM
spankaveli's Avatar
ttt
Old Apr 23, 2002 | 08:21 PM
CRX7's Avatar
I don't think the JRSC can flow well enough for a 2 liter vtec engine, there was a long discussion about this in the FI forum a while back. The consensus was it wouldn't work as the supercharget wouldn't be able to keep up.
Old Apr 24, 2002 | 08:30 AM
spankaveli's Avatar
Default Re: jrsc b20vtec? (CRX7)
jackson makes a s/c for the b20 now though. maybe i'll call em up and ask em.
Old Apr 24, 2002 | 08:55 AM
Quik Chris's Avatar
Do they make it for the B20/VTEC or just the B20.
It will flow perfectly fine for a B20/VTEC. If you're using a GS-R head, then yeah, get the one for the Geeser. But I'd say if you're going to do this, don't even consider using the stock B20B/Z pistons. Typically people will take the bore up from 84mm to 84.5mm. Probe racing makes a nice set with the propper valve releifs for a VTEC head. Also, you'd really be better off to save up more money and have the combustion chamber reworked on the head to accomodate the >84mm bore.
Bottom line is 6psi is 6psi, the .2L shouldn't make too big a difference.
Old Apr 24, 2002 | 10:25 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: jrsc b20vtec? (Midori Shinkansen)
It`s been done and bones the f___ out
I`m building this setup as we speak with a bored n sleeved gsr block. CC`s reworked, too. Should be assembled n installed in two weeks
sa90eg
Northern California (Sales)
Oct 19, 2012 10:27 AM
1slowcrx
Feb 10, 2009 12:20 PM
Jintegragsr97
Jan 21, 2008 01:28 AM
sepetinswenze
Nov 30, 2007 05:25 PM
gypsyhonda
Feb 15, 2002 02:14 PM
