how to install rpm tachometer
Old Apr 20, 2002 | 01:46 PM
hmonglonertim's Avatar
Default how to install rpm tachometer
it's a 96 hatchback with a b18c. which wire is the ignition (12+). and anything else i need to know.
Old Apr 20, 2002 | 02:18 PM
salbaje's Avatar
Default Re: how to install rpm tachometer (hmonglonertim)
red wire to ignition wire power when you turn key to on position
black wire ground
white wire goes to dimmer switch turns on light when you turn on lights
green wire goes to dist.
Old Apr 30, 2002 | 09:07 PM
Subtle's Avatar
Default Re: how to install rpm tachometer (salbaje)
Is that all there is to installing a tach (monster tach and shift light on the way)
Old Apr 30, 2002 | 09:42 PM
IgniteTeg's Avatar
Default Re: how to install rpm tachometer (Subtle)
yeah very easy
Old May 1, 2002 | 05:15 AM
Default Re: how to install rpm tachometer (IgniteTeg)
Got it. Thanks.
Old May 9, 2002 | 02:13 PM
urbantrain's Avatar
Sorry to bring this up again, but im kind of an idiot when it comes to electronics.. when you say the distributor, are you talking about some wire inside the dash, or run the wire all the way to the distributor on the engine?
Old May 9, 2002 | 02:21 PM
keebler65's Avatar
Default Re: how to install rpm tachometer (urbantrain)
if your car has a stock tach, you can tap off of that in the dash. if you look behind your gauge cluster, in the tach region, you should see 3 screws. those are for your tach (signal, +12v power, and ground). otherwise you can tap off of the distributor under the hood. its usually the blue wire that you want.
Old May 9, 2002 | 02:25 PM
urbantrain's Avatar
Default Re: how to install rpm tachometer (keebler65)
thanks man, i appreciate it!
teddy_dc2
Mar 15, 2007 07:02 PM
slimjimdanny
Jan 31, 2007 07:35 PM
bbhockey19
10
Jul 11, 2006 09:10 PM
Gonzo_SiR
Oct 29, 2003 10:12 PM
D1ANCER
Apr 2, 2002 11:05 PM
