vavle sounds?
Old Apr 23, 2002 | 04:35 AM
digitalhav0c's Avatar
Default valve problems?
if you valves are not adjusted right what kind of problems can you expect any wierd sounds?
[Modified by digitalhav0c, 1:36 PM 4/23/2002]
[Modified by digitalhav0c, 1:40 PM 4/23/2002]
[Modified by digitalhav0c, 1:42 PM 4/23/2002]
Old Apr 23, 2002 | 10:12 AM
bryant's Avatar
Default Re: valve problems? (digitalhav0c)
I know i need mine adjusted, because they make a clicking sound when the car is at idel.
Old Apr 23, 2002 | 11:15 AM
joeygill's Avatar
Default Re: valve problems? (CR-X)
do they also click/tick when the car is revved? and not just at idle..?
Old Apr 23, 2002 | 11:21 AM
sohc_boy's Avatar
Default Re: valve problems? (joeygill)
yes
Old Apr 24, 2002 | 03:44 AM
Default Re: valve problems? (sohc_boy)
i checked the compression yesterday and the first cylinder was like 60 points less than all the other cylinder's so i concluded that it must be a bent valve.
Old Apr 24, 2002 | 10:47 AM
GreenD's Avatar
welcome to the bent valve club
DCiFound
Sep 7, 2014 10:43 PM
Tegraracer90
Aug 6, 2008 09:33 AM
moesrex
May 23, 2006 08:55 AM
speedymon
Jan 14, 2002 10:08 AM
HX_Guy
Nov 7, 2001 08:39 AM
