gsr head on b16 bottom block
Old Jun 25, 2004 | 11:16 PM
EgxHaTcHxGsR's Avatar
Default gsr head on b16 bottom block
ok.. i kno this sounds hella stupid but gsr block is the only thing i got for my si head. if i was to do gsr head on b16 bottom block is that bad for the bottom block?
Old Jun 26, 2004 | 07:35 PM
f@sth@tch89's Avatar
Default Re: gsr head on b16 bottom block (EgxHaTcHxGsR)
no.....u will have more compression. the b16 head barely outflows the GSR. I have the same combo and will be going to the dyno soon.
Old Jun 26, 2004 | 10:41 PM
mmuller's Avatar
Mad Scientist
what really helps though, is being able to use the iab's from the gsr intake man. o the b16 with help midrange a lot
Old Jun 29, 2004 | 08:01 PM
8psisi's Avatar
im also about to run this setup.im thinking of putting 2 head gaskets because im also going turbo and the gsr head will add compression
Old Jun 29, 2004 | 08:02 PM
RI_TM's Avatar
Default Re: gsr head on b16 bottom block (fasthatch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 &raquo;</TD></TR><TR><TD CLASS="quote">no.....u will have more compression. the b16 head barely outflows the GSR. I have the same combo and will be going to the dyno soon.</TD></TR></TABLE>
keep us updated on that!
Old Jun 29, 2004 | 09:54 PM
Joseph Davis's Avatar
GSR head actually has quench... the difference in flow numbers is so close to identical as to be irrelevant. I would rather run a GSR head than a B16/ITR, y0
Old Oct 14, 2009 | 10:03 AM
yayizzil's Avatar
so wat was the out come...on the dyno and any upgrades too cause i am doing the same set up here
Old Nov 22, 2009 | 10:51 PM
st0xafella's Avatar
anyone know the torque specs on the head to block??
b18 hatch mike
Dec 15, 2007 12:31 PM
xxnuttybarxx
Oct 25, 2007 01:04 PM
maxheat
24
Feb 26, 2005 12:36 PM
EFin' Kyle
Aug 2, 2004 03:48 PM
CBR
Aug 19, 2002 07:18 AM
