how do you adjust a hydro clutch
Old Jun 26, 2004 | 05:38 PM
vjace's Avatar
Default how do you adjust a hydro clutch
ok i just put in a new exedy clutch im spouse to adjust the clutch
its a 96 integra the instruction that it came with just tells me to twist the rod in back of the master cylinder but i don't think thats right and i don't see a rod to twist
the car run nice as it is but i still wont to adjust the clutch so i can sleep better.
is the clutch spouse to grab as soon as you let go of the clutch or some were in the middle right now it grabs some were in the middle and im worried that the clutch is really don't engaged properly. i don't now im just a little paranoid it was my first time ever changing a hydro clutch. any help is appreciated thanx for any input.
and if you know any web sites that would help me do this that would help too.
Old Jun 26, 2004 | 08:57 PM
murtnabila's Avatar
Default Re: how do you adjust a hydro clutch (vjace)
if it grabs in the middle, you dont feel any slipping when completely engaged, and it dont keep moving even when clutch is pushed all the way in I would say ur clutch is set good already.
If it aint broke don't fix it, but if u just wanna know how to adjust the clutch just for the sake of knowledge then more power to you (to bad I can't help you there).
Old Jun 28, 2004 | 08:24 AM
vjace's Avatar
bump
thanx for the input murtnabila
Old Jun 28, 2004 | 09:47 AM
Sliced Beard's Avatar
the hydraulic clutch system was designed so that you do not have to adjust the tension
the slave cylinder adjusts to your specific clutch automatically
Old Jun 28, 2004 | 11:13 AM
Two_K Si's Avatar
You have to adjust the push rod so it does not travel to far. There is a tech-note included with exedy clutches describing why. I can snap a pic of what needs to be adjusted if you still do not understand
Old Jun 28, 2004 | 02:45 PM
vjace's Avatar
Default Re: how do you adjust a hydro clutch (Two_K Si)
that would be great
thanx
when i got my clutch i never got a tech note it would be great if you can send it to me or just tell me what it says thanx
Stonage07
Mar 6, 2017 11:48 AM
tigueremalo
Jan 14, 2007 02:29 PM
ethereal2pt2
Nov 7, 2006 02:07 PM
integra pride
Oct 12, 2004 03:58 AM
Buckshot
Sep 11, 2002 05:05 AM
