Block decking questions
Old Jun 30, 2004 | 11:31 PM
Pandahatch's Avatar
Default Block decking questions
I had my block decked to ensure it is perfectly straight for the build up. The front left corner was off pretty bad and the block had to be decked .0035. I have a few questions though, how can I tell what my new compression will be? It's a B20B block with a B16A head and 10.5:1 pistons. Nest is timing. What do I need to do to compensate for the decking? I want it to be on dead even timing right now. Do I need to adjust each cam gear?
Old Jun 30, 2004 | 11:40 PM
Kendall's Avatar
You shouldn't need to adjust either cam gear, you should be able to adjust the belt tensioner to compensate. Just calculate the compression the same as you would if you had milled the head by .0035.
Old Jul 1, 2004 | 09:31 AM
tgreaves's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't need to adjust either cam gear, you should be able to adjust the belt tensioner to compensate. Just calculate the compression the same as you would if you had milled the head by .0035.</TD></TR></TABLE>
Say what.. The timing belts distance is from the cam gears down the front of the motor to the crank pulley.. If you change the distance from them then you need to adjust the cam timing since the distance is shorter.. Adjusting the tensioner has nothing to do with bringing the cam timing back into spec, it just makes the belt tight..
Old Jul 1, 2004 | 12:15 PM
AzG35's Avatar
Default Re: (tgreaves)
.0035 is very little, but it will change your timing slightly. About a 1/3 of a degree. If you are worried about it, advance your gears by 1/3 and you should be close to 0 again.
Old Jul 1, 2004 | 12:21 PM
tgreaves's Avatar
Default Re: (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">.0035 is very little, but it will change your timing slightly. About a 1/3 of a degree. If you are worried about it, advance your gears by 1/3 and you should be close to 0 again.</TD></TR></TABLE>
I wouldnt worry about 1/3 of a degree..
Old Jul 1, 2004 | 12:31 PM
Pandahatch's Avatar
What will the new compression be though, I forgot how to calculate the new compression math wise and most compression calculators online just put in simple variables and nothing when it comes to decking.
DJ Gurgla GSR
Nov 28, 2005 10:08 AM
kartracer4
Jun 27, 2005 05:36 PM
fastsohc
Sep 28, 2004 09:50 PM
SupaFly_Honda
Nov 9, 2003 06:52 AM
