URGENT Broken bolt! while changing tire
Old Jun 25, 2004 | 08:24 PM
metal-x's Avatar
Default URGENT Broken bolt! while changing tire
I was changing my rims when i think put too much effort and snapped one of the bolts in half, can I drive the car with just 4 bolts? my car is a ITR
and also how can this be fixed and how much ! thanks alot
Old Jun 25, 2004 | 08:44 PM
MENACE's Avatar
Default Re: URGENT Broken bolt! while changing tire (metal-x)
Youll be fine with the 4 bolts. Just got to and auto parts store and order another stud. hammer the old one out. Put the new one in as far as it will go. Throw the rim on and tighten them all down and your set.
Old Jun 26, 2004 | 12:14 AM
IVI's Avatar
IVI
Default Re: URGENT Broken bolt! while changing tire (MENACE)
you will be fine with 4. youll be fine with even 3. if you take it to a shop its going to be 50-60 dollars for them to replace it. if you do it yourself the stud is a couple of dollars.
what you need to do, is :
1. take the tire off.
2. take the caliper + bracket off.
3. take off the rotor.
4. hammer the broken stud out just like its a nail.
5. slide the new stud in and line it up (some have a flat line and need to be lined up to the inside - compare to the other ones you have)
6. put a spacer (a bigger bolt that slides over works fine) and then put the lug nut over it
7. make sure the nut touches the spacer so it can pull itself tight.
8. tighten the lug nut and let the stud pull itself into place and get flush with the hub.
9. put everything you took off back.
its an easy do it yourself job. theres nothing heavy involved except maybe taking the rotor off you might need an impact screwdriver, thats it.
the rest a standard socket set would work fine.
Old Jun 26, 2004 | 05:39 AM
Civic168's Avatar
from what i remember... my father did it for me about 4 years ago in an ek. he had to remove the central hub nut.. as the stud dont just knock out.. i could be wrong i was young back then
Old Jun 26, 2004 | 10:38 AM
IVI's Avatar
IVI
Default Re: URGENT Broken bolt! while changing tire (Civic168)
itll knock out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic168 &raquo;</TD></TR><TR><TD CLASS="quote">from what i remember... my father did it for me about 4 years ago in an ek. he had to remove the central hub nut.. as the stud dont just knock out.. i could be wrong i was young back then</TD></TR></TABLE>
Old Jun 26, 2004 | 11:14 AM
RCautoworks's Avatar
Default Re: URGENT Broken bolt! while changing tire (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">itll knock out.
Unless the type R is different then the newer civics, you have to remove the hub because the stud is to long to just fall out.
Old Jun 26, 2004 | 05:18 PM
IVI's Avatar
IVI
Default Re: URGENT Broken bolt! while changing tire (90blackcrx)
if you spin it theres a spot for it to come out and go in from.
Old Jun 28, 2004 | 06:44 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">if you spin it theres a spot for it to come out and go in from.</TD></TR></TABLE>Not always. My '95 GSR has no such cutout in the steering knuckle. I don't know which years/models have that.
But if metal-x is talking about a REAR hub, I think there's plenty of room.
Old Jun 28, 2004 | 08:28 AM
B16CRXT's Avatar
I had to do this to my EF and I took the rear caliper/bracket and rotor off and used a brass hammer to knock the thing out. It took some effort, but it isnt hard.
(My rotor comes off when you take the calipers off)
Old Jun 28, 2004 | 08:46 AM
Default Re: URGENT Broken bolt! while changing tire (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Not always. My '95 GSR has no such cutout in the steering knuckle. I don't know which years/models have that.
Yeah the newer cars don't have these spots, the hole hub needs to be pulled off.
Old Jun 28, 2004 | 09:00 AM
vtecn8ive's Avatar
Yeah me and a buddy spent awhile on his (an EG) cause we needed to get the axle nut off (off the hub). I know next time I do it it will go by alot faster cause now I know what to expect.
felixb555
Jun 28, 2011 10:57 AM
chevyhonda
Apr 11, 2011 06:52 PM
HotCheetos
10
Dec 11, 2010 09:07 PM
vimsH22
Sep 21, 2005 12:36 PM
snoop_bealybob
Nov 22, 2002 09:23 AM
