2 easy questions
Old Jun 26, 2004 | 06:13 PM
Red_EM1's Avatar
Default 2 easy questions
1. when people say "rods" what part of the engine is that? as in "crank, rods and pistons". is it the part that connects the pistions to the crank?
2. how does coolant cool the engine? where exactly is it pumped? do the fans do anything other than just blow air at the engine?
Old Jun 26, 2004 | 06:25 PM
SOHC4life 96's Avatar
Default Re: 2 easy questions (Red_EM1)
http://www.howstuffworks.com/
all of your how does this work needs. and the rods connect the piston head to the crank shaft.
Old Jun 26, 2004 | 08:05 PM
GoGoGadgetVtec's Avatar
Default Re: 2 easy questions (DOHC4life)
coolant is pushed from the radiator around the cylindars and head, cooling them slightly, then back to the radiator to cool the coolant down to do it agian
Old Jun 26, 2004 | 08:13 PM
lilCivic's Avatar
coolent is pumped into the engine block which has small hole in it (when the head gasket blows u burn cooolent or oil) then the hot coolent goes in the raditor and cools off....it the same thiing ovre and over to cool the enginjne
Old Jun 26, 2004 | 08:32 PM
mnbv's Avatar
Default Re: (lilCivic)
You got #1 right. rods connect pistons to the crank. Pistons are a lot smaller then you may think. (At least I thought when I was learning)
Old Jun 26, 2004 | 08:41 PM
........'s Avatar
Default Re: (mnbv)
unless the pistons are from a BIG block chevy
adim
Oct 17, 2009 06:03 PM
all-mtr-teg
26
Jun 13, 2008 11:14 PM
Mike@CCT
28
Feb 28, 2005 10:09 PM
LudeyKrus
Jul 18, 2004 05:21 PM
JDMjdawg
Jul 15, 2004 12:55 AM
