Check Engine Light(knocksensor) comes on after i hit 45mph
Old Jun 28, 2004 | 11:38 PM
SivikHatch's Avatar
Default Check Engine Light(knocksensor) comes on after i hit 45mph
The code is flashing the knock sensor code. I wired it straight from the ecu to the knock sensor using a little speaker connector to attach it to the knock sensor's pin. The check engine light doesn't come on after i reset the ecu, but the moment i hit 45mph it comes on and stays for good. What you guys think could be wrong?
If its the style i use to wire the knock sensor causing the prob...anyone selling a plug for a knock sensor?
Old Jun 29, 2004 | 12:08 AM
honda_power69's Avatar
It would help if I knew what chassis/engine combination you're running, even if its a stocker. Also, that connector more than likely isnt doing its job. Try soldering it maybe...
Old Jun 29, 2004 | 04:18 AM
tommytoes's Avatar
Default Re: Check Engine Light(knocksensor) comes on after i hit 45mph (SivikHatch)
You should Probably try and find the right connector ...Junk yard maybe..
But you really should have a shielded cable going from the knock sensor to the ecu.
You can get the stuff pretty cheap at any hardware or radio shack style store.
acclude-vtec
Jan 2, 2006 11:00 AM
sheBangZ
Dec 20, 2005 03:26 PM
92HatchB16
Oct 1, 2005 05:05 PM
bak lee
Jul 26, 2005 08:58 AM
DOHCtorTHRUST
Apr 18, 2002 11:43 PM
