which is the higher rever??????
Old Jun 29, 2004 | 04:25 PM
akasen8's Avatar
Default which is the higher rever??????
ok i have a question which cams can be reved the highest on a built vavetrain but a stock bottom end the ctr or the itr n which gives u the best overall power?????
Old Jun 29, 2004 | 04:36 PM
Shawn C's Avatar
In The Garage
ctr has the craziest profile, but you'll need a mildly p&p'd head, a good intake manifold, and high compression (~10.5:1 - 12:1)
Old Jun 29, 2004 | 06:08 PM
akasen8's Avatar
ok what if i have a skunk2 intake manifold on a stock b18c1 block
Old Jun 29, 2004 | 10:37 PM
B16A1-EF9's Avatar
Default Re: which is the higher rever?????? (akasen8)
CTR cams will run fine on any of the vtec b-series motors. I've run them on stock b16a's without any problems. Mind you, the vtec crossover was always over 5000. Not sure how they would react if vtec was turning on below that rpm.
Get cam gears for them too so you can dial them in right.
crazihobo
Oct 12, 2011 02:48 PM
nikanoras
Dec 24, 2009 10:16 AM
black_EM1
Aug 5, 2008 06:09 AM
TEGPOWER44
Dec 12, 2002 06:11 PM
Qwikrex
Dec 2, 2002 06:03 PM
