NEED HELP PLEASE PLEASE, CAR WONT START!!!!!!!!!!!!
Old Jun 28, 2004 | 04:59 PM
THMotorsports's Avatar
Default NEED HELP PLEASE PLEASE, CAR WONT START!!!!!!!!!!!!
I have a 97 Integra GS with a b18b turboed. Today I showed it to a friedn who wanted to buy it and he ran a compressiuon test on it. So we did what had to be done, pulled the wires, plugs and ran the test by cranking the motor over. Car ran a 150 accross the board. Ok, it was good. Put everything back on RIGHT. The wires were perfect onto the cap in the correct firing order. EVEN got new plugs and gapped them to .44" to make sure the car would run good. So i go to turn the motor and nothing . It just cranks adn cranks, but never turns.
So this is what we tried:
1. REchecked all wires on the dizzy to make sure they were right and they were
2. Got new plugs to make sure
3. Checked all fuses and replaced one - nothing happen when changed (it was a backup fuse)
4. Checked fuel pump and it works bc when you put the key to almost on, it makes a good amount of noise and it works.
Whenever the plugs were pulled, they were dry even though they were turned. Each plug was just taken out and held on the wire and none sparked??? That seems to be a problem, but it doesn smell like there is fuel going to motor so its so confusing. Spent about 5 hours on it and no idea What the hell is going on.
Old Jun 28, 2004 | 05:12 PM
Default Re: NEED HELP PLEASE PLEASE, CAR WONT START!!!!!!!!!!!! (Truehondacom)
HELPPPPPPPPPPPPP!!!!!!!!!
Old Jun 28, 2004 | 05:22 PM
devnull's Avatar
Sounds like your wires are bad. Try a different set or a NEW set. Good luck.
Old Jun 28, 2004 | 05:36 PM
Default Re: (qi_doy)
Im going to do an electrical test on them tomorrow, any more suggestions.
Eddie
Old Jun 28, 2004 | 05:39 PM
Default Re: (Truehondacom)
I was told that it might be the ECU???
I will check it all tomorrow.
Eddie
micah13x
11
Apr 14, 2011 03:09 PM
88crxdxfastwhip
Dec 2, 2010 02:43 PM
JAYDmManny1331
Nov 22, 2009 09:33 PM
steveo135
Jan 8, 2008 06:55 PM
