need help on ls motor
Old Jun 28, 2004 | 09:43 AM
TspEk9's Avatar
Default need help on ls motor
does anyone know the torque specs for bolting the head on a b18b, and should i use all three layer gasket?
Old Jun 28, 2004 | 09:58 AM
b18bturbo's Avatar
Default Re: need help on ls motor (TspEk9)
use factory three layer gasket what head bolts are you using that would make a difference
Old Jun 29, 2004 | 12:24 AM
TspEk9's Avatar
im using gsr head bolts, i have gsr pistons in the b18b,and that'll give me a lil more compression, but i want a lil more compression close to 10, if i put 2 layer the c/r would be at 9.8, so do u think 2 layer is a lil safe? cause im not sure about 1 layer head gasket
Old Jun 29, 2004 | 12:30 AM
honda_power69's Avatar
You can just use a stock-style or a Mr. Gasket one and drill out the rivets & remove the inner (center) gasket piece of the 3-layer. It'll be fine, there shouldnt be any trouble whatsoever using a 2-layer on your application. I'm sure you know, but just be sure to use the head gasket for the b18b or b18a...you dont want one with a vtec oil galley in it.
Old Jun 29, 2004 | 03:51 PM
TspEk9's Avatar
and i also need help on when i put the head on, how do u set all the timing?
Old Jun 29, 2004 | 04:32 PM
redlineintegra's Avatar
Default Re: (TspEk9)
You're using GSR head bolts on a b18b?
Old Jun 29, 2004 | 06:33 PM
TspEk9's Avatar
why not? it wont fit?
Old Jun 29, 2004 | 07:22 PM
I could be wrong, can't find a thread to verify, but I thought the GS-R studs were longer?
Old Jun 29, 2004 | 08:48 PM
Thrillhouse's Avatar
Default Re: (redlineintegra)
why not just do it right, buy some NEW B18B bolts or some ARP, you are not supposed to re-use head bolts, when they are torqued they are actually being stretched. I think spending the 100 bux for studs or 45 bux for new OEM bolts is CHEAP insurance for the possibilities of a blown gasket, cracked, warped head or block.
Old Jul 1, 2004 | 11:27 AM
TspEk9's Avatar
i decided to go with arp head bolts, but my other question is, when i put the head on, how do i set the timing? should i align the crank pully mark with the timing mark on the cover? and should i put the cams facing upwards?
912.2Accord
Jan 7, 2012 07:01 AM
ej1_lsvtec
Jan 5, 2006 06:11 AM
PhatBoy5015
Dec 9, 2005 07:39 PM
Lewcis
Jun 24, 2004 11:02 PM
DLB1994
Feb 23, 2002 10:17 PM
