trouble code
Old Sep 12, 2004 | 06:32 AM
ironryder's Avatar
Default trouble code
i got a 98 civic and the check engine light is on.....i just wondering anyone know how to get the trouble code without a scanner?? or is it even possible??
thanks
Old Sep 12, 2004 | 08:22 AM
rev-speed's Avatar
same way as obd1
on the passenger kick panel theres a blue connector jumper the two wires and turn the igniton key to on then count the codes
Old Sep 14, 2004 | 08:22 PM
ironryder's Avatar
hmmmmm........the OBDll connector is on the driver side and i check the passenger kick panel and don't have anything blue there.could it be it is a Canadian car eh??
lets say the OBD connector is the same which pins do i jump??
Old Sep 14, 2004 | 08:25 PM
deSigi's Avatar
https://honda-tech.com/zerothread?id=682412
Very useful.... should answer most of your question.
Old Sep 15, 2004 | 07:06 AM
ironryder's Avatar
P0420 Catalyst System Efficiency Below Threshold.........what does that mean?? do i have to change my cat??
Old Sep 15, 2004 | 09:23 PM
PrettyLude's Avatar
did u gut the cat? if you did to cure this problem and solve the check light, go and purchase a o2 simulator
Old Sep 17, 2004 | 05:57 PM
ironryder's Avatar
no i didn't gut the cat...every thing is stock.the car only have 58k since i got it new.so i guess it would be either the o2 sensor or the cat right? so how can i find out which one is not working right?
bma1818
Apr 19, 2006 09:55 PM
Dodger2940
12
Dec 15, 2005 10:54 AM
poop32145432
Aug 5, 2004 01:48 PM
Mires
Jul 3, 2003 07:37 AM
Log4n
Mar 15, 2003 05:11 AM
