Main caps/bearing question.
Old Sep 10, 2004 | 06:20 PM
tilt.'s Avatar
Default Main caps/bearing question.
i am currently stroking my gsr, with an ls crank/rods and i need to get new main bearings....so do i order bearings for a b18b, or a b18c1?
Old Sep 11, 2004 | 10:49 PM
chrisCNL's Avatar
Default Re: Main caps/bearing question. (dr_jdm)
Ls rod bearing, GSR and LS share the same MAin bearings.
Old Sep 13, 2004 | 12:47 PM
tilt.'s Avatar
Default Re: Main caps/bearing question. (chrisCNL)
what color should i use?
Old Sep 13, 2004 | 03:19 PM
chrisCNL's Avatar
there are numbers on the crank and block for the main bearings if you are using OEM...There is a chart that you have to use to identify the color...As for the rod if you are using the aftermarket rod. just get the Green bearing from honda.
Rheg6
Jan 9, 2012 06:36 PM
blackcrx16
Oct 15, 2007 06:45 AM
eg4life1202
11
Jan 14, 2007 09:17 AM
VtecnTurbo
Oct 8, 2006 07:16 AM
geezer_aMr
Oct 7, 2004 05:46 AM
