HEAD BOLTS STRIPPED HELP!!
Old Sep 9, 2004 | 07:42 PM
SiB16A's Avatar
Default HEAD BOLTS STRIPPED HELP!!
1 of my head bolts stripped.. any tips on taking it off?? should i drill it?
Old Sep 9, 2004 | 08:06 PM
Kamin's Avatar
Default Re: HEAD BOLTS STRIPPED HELP!! (SiB16a)
try a bolt extractor first, if that dosent work talk to your machine shop. its probably best they tackle it rather than you drilling.
Old Sep 9, 2004 | 08:09 PM
Antilag's Avatar
so you cant take it out? I think sears has those special sockets for stripped bolts, someone has used it and it actually worked.
Old Sep 9, 2004 | 09:46 PM
SiB16A's Avatar
Default Re: HEAD BOLTS STRIPPED HELP!! (9sech22civic)
i bought it doesnt fit where the head bolt is.. h22 vtec
Old Sep 9, 2004 | 09:58 PM
rev-speed's Avatar
i had this problem before
buy some reverse drill bits and drill it out
make sure if they don t come out
then just helicoil the bitch!!!but they will come out i drilled out a broken crank bolt before
thank god for who ever invented reverse drill bits
Old Sep 10, 2004 | 09:20 AM
b20turbojason's Avatar
Default Re: HEAD BOLTS STRIPPED HELP!! (4cylinder)
you stripped the head of the bolt or you stirpped the threads of the head bolt.
if you stripped the head of the bolt man it is going to take some luck and some time. the only thing i know of that i would do would be to take a socket that is a little bit smaller that you have to hammer on it and then try takeing it off. only prob is there is so much torque on that bolt it might make it a little diffacult to come off.
Old Sep 10, 2004 | 01:33 PM
SiB16A's Avatar
Default Re: HEAD BOLTS STRIPPED HELP!! (b20turbojason)
i tired hammering a smaller socket... it didnt work.. i ended up have to drilling didnt get it out yet.. it got dark outside gonna give another shot soon
Old Sep 10, 2004 | 10:06 PM
rev-speed's Avatar
no my buddy over torque a head bolt and broke one
i then had to deal with it
i drilled it out with reverse drill bits then
next he strips the the hole
so then i helicoil it and now that motor is still runiing strong on 80 shot direct port
thanks to helicoil and reverse drill bits
Old Sep 20, 2004 | 06:06 PM
prestonpark's Avatar
henry to much power that why
notnilc20
May 14, 2011 12:09 AM
98ekgsr617
Sep 5, 2009 12:52 PM
bow tie
Nov 15, 2008 05:11 PM
Beau Gotti
Sep 10, 2006 12:25 PM
ltho1998
Aug 16, 2003 06:59 PM
