Car running cold?
Old Sep 14, 2004 | 02:27 PM
crx_kid's Avatar
Default Car running cold?
I noticed that my car has been running cold lately. It's a 2000 Type R. The needle on the temp gauge dip back into the cold zone when ever I press on the gas. While in idle, the temp is find. But once I get moving, the needle just drops back to C. I dont think there's anything wrong with the temp. sensor, cause the lower rad hose was actually cool. I think it might be the thermostat. Could it be stuck open? But the car only has 76,000 kms on it , so I don't think it should go bad this soon. Anyone have this similar problem before? Can someone help me out?
Thanks.
Old Sep 14, 2004 | 03:18 PM
non-VTEC's Avatar
Default Re: Car running cold? (crx_kid)
sounds like the themostat is stuck open........replace it....not that big a deal......
Old Sep 14, 2004 | 08:13 PM
crx_kid's Avatar
Default Re: Car running cold? (non-VTEC)
well I talked to the dealer today. They said that the thermo is only warranteed for 3 years/36,000 kms. My car is now 4 years old so it's not covered. But does thermos got bad this soon? The guy from the dealer told me that it might be something else cause thermos don't usually go bad this soon. He said that they usually last for like a 100,000 kms or more b4 going bad. Well I just think that they want to make some money for the work.
So does thermos ever go bad so soon? maybe I got a defective one? Why else would Honda only warrantee it for 3 years?
Old Sep 14, 2004 | 08:26 PM
krazie1's Avatar
BANNED
the dealership will always try to sucker u into more labor time
a termostat can go bad just like other parts sooner then later
I have seen a timing belt go bad after 50,000 miles
and others have lasted over 200,000 miles!!!
so u know I would
if u can get the manual and a six pack of beer
DO IT URSELF
easiest thing next to doing ur oil change
right guys
Old Sep 14, 2004 | 09:26 PM
92bubblesi's Avatar
I know this may sound wierd but check your grounds. I was having a similar issue except my car would run normal temp while at idle but under load it would read hot. I found out my tranny ground bolt was stripped because of a crappy shop (Thanks DragTec). After I fixed it everything was fine.
Just something to check.
Old Sep 15, 2004 | 12:42 AM
crx_kid's Avatar
Default Re: Car running cold? (krazie1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">the dealership will always try to sucker u into more labor time
so u know I would
DO IT URSELF
right guys </TD></TR></TABLE>
Yeah I know it's an easy fix, but I just wanted to see if anyone else have had a similar problem as me and to see if there was a possibility that something else can be wrong before I go start taking stuff apart and order a new thermostat.
But yeah, I'll check the ground tomorrow. Thanks
Old Sep 15, 2004 | 03:18 PM
hedturner3816's Avatar
like the guy before me said check all your wires that run to it because one might be loose or something i had the problem wiht my old car just tightened the one wire and she worked PERFECT.
Old Sep 15, 2004 | 04:55 PM
sporkcrx's Avatar
Default Re: Car running cold? (hedturner3816)
Just replace the thermostat, it's like $20, and if it's not the problem, you can consider it preventative mantainance
strykr89
11
Apr 15, 2013 04:13 AM
Rob.
Oct 6, 2008 08:34 PM
longuyen88
Feb 5, 2007 08:02 AM
streetracerof06
Dec 7, 2005 10:01 PM
crx_kid
Sep 15, 2004 06:22 PM
