hard time restarting b18c5
Old Sep 9, 2004 | 06:09 PM
92bubblesi's Avatar
Default hard time restarting b18c5
Hey guys I am having a hard time starting my gsr to itr conversion when it is hot. It usally happens if I go into the store and come back out to start it. My setup is a b18c1 block with a itr intake manifold/throttlebody/ and head. The ecu is a obd1 p72. I am not throwing any nodes.
I can think of one thing that might cause the problem. I am using the gsr fuel rail. When installing the injectors there was no room for the hard plastic heat insulators that go between the IM and the fuel rail. Do you guys think this would make a big difference in hot starting. I am been meaning to get the itr fuel rail but I had forgotten about it until now.
Old Sep 9, 2004 | 07:07 PM
markaria's Avatar
Default Re: hard time restarting b18c5 (92bubblesi)
Sounds like a main fuel relay. good luck
Old Sep 9, 2004 | 08:06 PM
92bubblesi's Avatar
Default Re: hard time restarting b18c5 (markaria)
I can hear the relay and the fuel pump kick on for the first two seconds when I move the key to on. In fact that is how I get it started. I turn the car to on, wait for the fuel pump to turn off. I then turn the ignition back off, back to on, and it restarts ok.
Old Sep 9, 2004 | 10:13 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92bubblesi &raquo;</TD></TR><TR><TD CLASS="quote">I can hear the relay and the fuel pump kick on for the first two seconds when I move the key to on. In fact that is how I get it started. I turn the car to on, wait for the fuel pump to turn off. I then turn the ignition back off, back to on, and it restarts ok.</TD></TR></TABLE>
u just solve ur own problem
u have to turn the key on and off to run the fuel pump first
sounds like ur loseing fuel pressure
check 4 fuel pressure, leak down pressure,and volume
Old Sep 9, 2004 | 10:56 PM
92bubblesi's Avatar
Default Re: hard time restarting b18c5 (4cylinder)
According to my fuel pressure guage I am not loosing any fuel pressure
Old Sep 10, 2004 | 10:28 PM
rev-speed's Avatar
how about fuel flow?
u might have air in ur system
i think u should borrow a dist and try it.
or when it gets hot when u first crank it check 4 spark
Old Sep 14, 2004 | 07:29 PM
92bubblesi's Avatar
Default Re: (4cylinder)
I am trying to buy another distributor to give that a try. I am wondering if I am boiling the gas in the fuel rail or something.
Old Sep 14, 2004 | 09:48 PM
rev-speed's Avatar
never seen that happen before
Old Sep 14, 2004 | 10:10 PM
92bubblesi's Avatar
I haven't either that is why I am asking.
Jruiz3505
Dec 6, 2011 02:40 PM
gwilguy
Aug 22, 2010 04:35 PM
onekoop
Jan 30, 2005 12:36 PM
Lou_Cypher
Oct 1, 2003 10:29 AM
