Running B20vtec w/ GSR ecu?
Old Sep 9, 2004 | 05:59 PM
Propulsion's Avatar
Default Running B20vtec w/ GSR ecu?
Planning to use ITR cams, looks like the appropriate vtec engagment should happen at about 4.5k rpm w/ these cams.
Main concern is about the IAB stuff? Is there a way around this? WOuld there be any problems w/ running the gsr ecu if I tune the fuel w/ a fpr?
Old Sep 9, 2004 | 06:02 PM
mmuller's Avatar
Mad Scientist
Default Re: Running B20vtec w/ GSR ecu? (SilverCIVIC96)
as far as the iab's, you'll be fine
i dunno, you gonna run lean, and if you up it up with the fpr; timing will still be off.
bigger bores need more timing/
ill say get it tunned
Old Sep 26, 2011 | 05:26 PM
robertnduncan's Avatar
Any one else have experience with this setup?
I have a b20b currently running in my car, just rebuilt a gsr head completely stock. I have an obd1 p72 that I want to use until I get it tuned.
Will this blow up in my face?
Thanks,
SOL-Hatchback
Nov 8, 2007 08:03 AM
ahemming06
Feb 14, 2007 05:56 AM
DusdmCgsr2
19
Oct 1, 2006 08:49 PM
Book Readar
Nov 6, 2004 11:38 PM
