Oil ring filing
Old Sep 10, 2004 | 02:05 PM
db2integra's Avatar
Default Oil ring filing
The spec sheet I recieved from JE pistons says that the oil ring should be gapped to no more less than .0015 inches. I installed the top and bottom oil rings into the cylinder, and found them to already be wider than this tolerance, yet when I install the rings onto the piston the corregated center spacer prevents the assembly from compressing onto the piston. Is this spacer ring meant to be filed as well, or is it meant to be compressed as a spring?
Old Sep 10, 2004 | 02:24 PM
db2integra's Avatar
Default Re: Oil ring filing (db2integra)
Bump.
Old Sep 10, 2004 | 07:29 PM
Garcia-Racing's Avatar
If it's a turbo motor you probably want to run bigger than .0015 on the compression rings anyways. Depends what type of setup you are doing. The oil ring also uses 2 rings to compress it and hold it in place.
EKB18BPR3
Jul 4, 2007 04:54 PM
jtracing919
Jan 25, 2006 05:06 PM
N20civicB18
Oct 25, 2004 06:55 AM
crx1856
Sep 18, 2003 02:34 AM
