Main Bearing bridge/block girdle
Old Sep 12, 2004 | 06:44 AM
crexer's Avatar
Default Main Bearing bridge/block girdle
OK im a little confused....I know that ls/gsr have a block bridge or girdle whatever you wanna call it and I also know that a b20 has one. Does the b16a have a block girdle? In my haynes manual it is showing one for "VTEC models only" but thats not specific enough. I have heard that b16's dont have the bridge but can someone verify for sure? Reason i want to know is im working on putting my engine together from scratch and I know i didnt use or have a block girdle in there.
Old Sep 12, 2004 | 07:33 AM
mmuller's Avatar
Mad Scientist
Default Re: Main Bearing bridge/block girdle (crexer)
only b18c blocks have them, non-vtec and b16/b17 dont have them
Old Sep 12, 2004 | 07:58 AM
rev-speed's Avatar
called block gridle
z10 makes an after market one and theres a special one that is wider which covers all the main bearing
Old Sep 12, 2004 | 08:13 AM
Used2beAb16's Avatar
Default Re: Main Bearing bridge/block girdle (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">only b18c blocks have them, non-vtec and b16/b17 dont have them</TD></TR></TABLE>
Old Sep 12, 2004 | 08:16 AM
crexer's Avatar
Default Re: Main Bearing bridge/block girdle (Used2beAb16)
so im guessing that you can bolt a block girdle in a b16 from a b18c?
Old Sep 12, 2004 | 10:17 AM
johnb18a1doe's Avatar
IF it can be done you need to get your main bores align-bored on an align boring machine i believe.
Old Sep 12, 2004 | 12:02 PM
LudeyKrus's Avatar
Default Re: Main Bearing bridge/block girdle (johnb18a1doe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnb18a1doe &raquo;</TD></TR><TR><TD CLASS="quote">IF it can be done you need to get your main bores align-bored on an align boring machine i believe.</TD></TR></TABLE>
I believe you are wrong.
Old Sep 12, 2004 | 04:37 PM
TeamCracka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">so im guessing that you can bolt a block girdle in a b16 from a b18c?</TD></TR></TABLE>
Some machine work is necessary to use a B18's girdle on a B16, I believe a couple of the bolt holes are different widths.
Old Sep 17, 2004 | 07:03 AM
96MidoriHatch's Avatar
Default Re: Main Bearing bridge/block girdle (TeamCracka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">
I believe you are wrong.</TD></TR></TABLE>
are you sure i have heard that too. or do you only have to do it on ls and b20?
Old Sep 17, 2004 | 10:24 AM
LudeyKrus's Avatar
Default Re: Main Bearing bridge/block girdle (96MidoriHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96MidoriHatch &raquo;</TD></TR><TR><TD CLASS="quote">
are you sure i have heard that too. or do you only have to do it on ls and b20?</TD></TR></TABLE>
The only reason one should need to get an align bore done on their mains is if the main caps/saddles are warped, scoured, or you need to run a crank w/ bigger journals. Just throwing a girdle on the caps will not do any of these, so an align bore should not be needed.
If one of the B-series cranks uses a crank w/ bigger journals on the mains, THEN you could do an align bore to give you the bigger mains you need.
Old Sep 17, 2004 | 11:29 AM
acy76's Avatar
Default Re: Main Bearing bridge/block girdle (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">The only reason one should need to get an align bore done on their mains is if the main caps/saddles are warped, scoured, or you need to run a crank w/ bigger journals. Just throwing a girdle on the caps will not do any of these, so an align bore should not be needed.
If one of the B-series cranks uses a crank w/ bigger journals on the mains, THEN you could do an align bore to give you the bigger mains you need.</TD></TR></TABLE>
When I installed an Endyn girdle on my LS block, I was advised by the machine shop to hone the mains, as the girdle can twist things out of shape when torqued down and cause bearing problems. There have been threads discussing this before. Here is one: https://honda-tech.com/zerothread?id=162919
For those interested, this thread shows the procedure for properly installing a GSR/ITR girdle onto an LS block: https://honda-tech.com/zerothread?id=263598
Old Sep 17, 2004 | 11:39 AM
LudeyKrus's Avatar
Default Re: Main Bearing bridge/block girdle (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">
For those interested, this thread shows the procedure for properly installing a GSR/ITR girdle onto an LS block: https://honda-tech.com/zerothread?id=263598</TD></TR></TABLE>
Well I stand corrected
I did not know that the girdle can cause the mains to flex some when torqued down. I figured having them dowel'd would be a good idea, but looks like an align bore would be a great idea, too.
Old Sep 17, 2004 | 02:54 PM
align bore is needed sometimes, but ive seen cases where they just torqued down the block and everything was a go.
For example, my motor wouldnt turn over with the girdle torqued down so i got it bored and im kinda glad i did because it just turns over soo nice on the stand
But, another dude here just bolted his in and it turned over fine and now has 20,000 + miles on it
oh, and b16's have no need for a girdle. Stock bottem end good for 9000+
Old Sep 17, 2004 | 03:51 PM
crexer's Avatar
thanks for all your replies....I was just really hoping that my b16 wasnt missing the girdle but now I know it never had one
CrazyHB
May 13, 2005 12:29 PM
Jockdeeznutz
Feb 28, 2004 09:51 AM
92 civic VX B18c
Jan 25, 2004 07:18 PM
B_CRUZ!
Feb 6, 2002 10:06 AM
