Hondata Emulator Question
Old Sep 13, 2004 | 06:30 PM
TurboTeG4's Avatar
Default Hondata Emulator Question
I just got my high speed keyspan adapter for my del laptop, So I have my programmer to the printer port, datalogging to my serial port Com1, but now I insert my usb adapter to the usb port and to my romulator. What do I select as Com? I selected romulator and went through all the serial port coms and it says Error Could Not Open Romulator for everyone. Does the emulator have to be also connected to the ecu, how do I get it to recognize my emulator?
Old Sep 13, 2004 | 10:45 PM
TurboTeG4's Avatar
Default Re: Hondata Emulator Question (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">I just got my high speed keyspan adapter for my del laptop, So I have my programmer to the printer port, datalogging to my serial port Com1, but now I insert my usb adapter to the usb port and to my romulator. What do I select as Com? I selected romulator and went through all the serial port coms and it says Error Could Not Open Romulator for everyone. Does the emulator have to be also connected to the ecu, how do I get it to recognize my emulator?</TD></TR></TABLE>
Old Sep 13, 2004 | 10:49 PM
rev-speed's Avatar
download rom editor
open it on the top right click on help
the go into registor and enter ur install number
Old Sep 14, 2004 | 07:25 AM
b18cls1's Avatar
the romulator has toi be connected to a ecu thats where it gets its power from, most of the time the usb port will be com5
Old Sep 14, 2004 | 10:34 AM
Spunkster's Avatar
Check the device manager to see what com port the USB adapter is using.
Old Sep 14, 2004 | 11:19 PM
TurboTeG4's Avatar
Default Re: Hondata Emulator Question (b18cls1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 &raquo;</TD></TR><TR><TD CLASS="quote">
the romulator has toi be connected to a ecu thats where it gets its power from, most of the time the usb port will be com5</TD></TR></TABLE>
But it says to connect it to the ecu after it says to open it in romeditor
Old Sep 15, 2004 | 06:26 AM
b18cls1's Avatar
But it says to connect it to the ecu after it says to open it in romeditor</TD></TR></TABLE>
when i tune with thr romulator i install the romulator into the ecu then hookup my laptop turn the ign on then open romeditor check your settings to see if the romulator is being recognized , it powers up from the ecu so if the ign is off it wont see it since the romulator has no power.
Old Sep 16, 2004 | 06:56 PM
TurboTeG4's Avatar
Well I just tested the emulator and it works, only thing is I got another problem.
If I datalog with romeditor it works, but I cant datalog with romeditor and run hondalogger at the same time. Its either one or the other, the other one will not connect, why is this. Also I emulated a stock gsr program on the p28 but at idle position sometimes when I just give it a really slight press on the throttle, I feel it hesitate a tiny bit, why is this on a stock map?
Old Sep 16, 2004 | 09:25 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Well I just tested the emulator and it works, only thing is I got another problem.
If I datalog with romeditor it works, but I cant datalog with romeditor and run hondalogger at the same time. Its either one or the other, the other one will not connect, why is this. Also I emulated a stock gsr program on the p28 but at idle position sometimes when I just give it a really slight press on the throttle, I feel it hesitate a tiny bit, why is this on a stock map?</TD></TR></TABLE>
allot of times the logger and emulator are setup to use the same com port,
Old Sep 16, 2004 | 09:50 PM
TurboTeG4's Avatar
Well I can datalog with the editor, but the hondalogger cant run at the same time, the emulator is at my com2 with a keyspam sub to serial.
Old Sep 19, 2004 | 12:18 AM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Well I can datalog with the editor, but the hondalogger cant run at the same time, the emulator is at my com2 with a keyspam sub to serial.</TD></TR></TABLE>Also how come it hesitates just a tad sometimes when it idles and I give it slight throttle with a stock 72 base map
Old Sep 20, 2004 | 05:53 PM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Also how come it hesitates just a tad sometimes when it idles and I give it slight throttle with a stock 72 base map</TD></TR></TABLE>
Old Sep 23, 2004 | 07:20 PM
TurboTeG4's Avatar
Where is my a/f ratios coming from when I datalog, Im getting all kinds of odd readings and my uego is not hooked up
illi Adik
Acura TSX
Sep 16, 2008 08:26 AM
Bayareajdm
May 17, 2007 10:39 AM
96gsrhatch8230
Jan 19, 2007 10:14 PM
blacksniper
Jul 29, 2004 04:45 AM
ForceFed Coupe
Apr 8, 2004 09:04 PM
