refill plug tranny b16a2
Old Sep 14, 2004 | 09:51 AM
dnbruut's Avatar
Default refill plug tranny b16a2
can anybody tell me where i can find the refillplug on my b16a2tranny? because there are 3 possible plugs! 1 on the diff a few inches higher than the draining plug and 2 on the end off the tranny?i had the same issue ones with a renault and i just screwed one out....PLOING I made it a 4speed gearbox!
thanks in advance!
Old Sep 14, 2004 | 11:04 AM
Sliced Beard's Avatar
Default Re: refill plug tranny b16a2 (dnbruut)
the refill hole is above the drain plug beside where the CV axle inserts into the differential
Old Sep 14, 2004 | 11:32 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: refill plug tranny b16a2 (DirtySol)
just drain the tranny, remove the speedo sensor and refill with 2.9 quts, screw the fill plug
Old Sep 14, 2004 | 11:34 AM
mmuller's Avatar
Mad Scientist
Default Re: refill plug tranny b16a2 (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">just drain the tranny, remove the speedo sensor and refill with 2.9 quts, screw the fill plug</TD></TR></TABLE>
Old Sep 14, 2004 | 11:55 AM
Default Re: refill plug tranny b16a2 (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Here's where the trick comes in that will save you headahces. Usually you have to ghetto-rig a funnel and tube to fill the tranny in the fill hole which really sucks. My method is really easy.
1. Remove the vent cap found near the front/top of your tranny:
2. Find the Speed sensor located on the topside of the very back of your tranny:
3. Take the 10mm on a big-*** extension and remove the bolt (it's the orangish one in my pic - yours probably won't be oragnish):
4. Now see that big-*** hole left after you move the speed sensor out of the way? Use the funnel and fill through that hole! By the way, no need to unplug the speed sensor - just move it out of the way.
5. Fill up with specified amount or until fluid dribbles from the fill hole below.
6. Put the speed sensor back in, tighten up the fill plug (if you loosened it).
7. Replace the vent cap and you're done!</TD></TR></TABLE>
through a quick search, this is what I found.......the original post WITH pictures can be found here
VtecAdvantage
Mar 30, 2010 10:10 PM
vtec4lyfe
25
Jan 20, 2007 06:14 PM
Touge Tuning
Oct 12, 2006 01:55 PM
colinproctor
Mar 2, 2006 01:52 PM
SimbaDogg
Dec 21, 2003 06:25 AM
