Could this be a grounding issue?
Old Sep 13, 2004 | 06:37 PM
Boostage's Avatar
Default Could this be a grounding issue?
94 ex..here is what happens, my dome light works forlike 2 days a week, my trunk light has came on only 3 times since I have owned the car. the other day my windsheild wiper wouldnt come on when I pushed the switch/lever down, however it worked when I turned the ****. it now works when I push teh lever down, but i gurantee next week it wont work.
and my cigarette lighter comes on and goes off all the time. I know this because I have my cell phonce charger in it and the led will be on, for like 10 mins and then go out. could all these probles be bad grounds?
Old Sep 14, 2004 | 05:22 AM
Boostage's Avatar
Default Re: Could this be a grounding issue? (Boostage)
help
Old Sep 14, 2004 | 05:37 AM
EE_Chris's Avatar
Yes.
Old Sep 14, 2004 | 05:41 AM
Boostage's Avatar
Default Re: Could this be a grounding issue? (EE_Chris)
how many ground wires are on the car? I see teh obvious one on teh valve cover and one on the tranny. ho wmany more and where?
Old Sep 14, 2004 | 06:07 AM
JimBlake's Avatar
There's a ground connection for each & every circuit in the car. For example there's a wire at the taillights that screws to the body somehow. There's a bunch of them under the dash somewhere, others are all over the car.
When one is disconnected, that circuit doesn't work properly. But sometimes it grounds itself thru another circuit, then you get really interesting problems.
Take a look at EE_Chris's signature. You might want to get your hands on a wiring drawing...
Old Sep 14, 2004 | 09:28 AM
COUPE-B20's Avatar
Has the car ever been flooded??
Old Sep 14, 2004 | 11:59 AM
Boostage's Avatar
Default Re: (COUPE-B20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COUPE-B20 &raquo;</TD></TR><TR><TD CLASS="quote">Has the car ever been flooded??
not that I know off
Old Sep 14, 2004 | 02:15 PM
Boostage's Avatar
up
Old Sep 15, 2004 | 04:25 AM
EE_Chris's Avatar
What more are you hoping we can do for you?
It seems you won't pony up for a Helms and can't find an online version, so other than you getting out there, tracing wires with your hands/eyes and making sure all connections are clean and tight, you're about done as far as troubleshooting goes.
Old Sep 15, 2004 | 05:07 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">What more are you hoping we can do for you?
It seems you won't pony up for a Helms and can't find an online version, so other than you getting out there, tracing wires with your hands/eyes and making sure all connections are clean and tight, you're about done as far as troubleshooting goes.</TD></TR></TABLE>
I wanted to see if it could have been something other than grounds, I will check that for sure asap. but until then I bumped teh thread to see if anyone else might have had these something and its something else.
Old Sep 23, 2004 | 11:10 AM
COUPE-B20's Avatar
Check and make sure all your pin locations r in the right place and check all the connections..................voltage and grounds..
scrubachu
May 10, 2009 11:28 PM
tomii.dc-5
Honda Civic (2006 - 2015)
14
May 3, 2009 01:02 AM
Z.E.R.O.
Apr 7, 2009 06:32 PM
Racersky
Audio / Security / Video
Nov 19, 2005 09:36 PM
Boostage
Sep 14, 2004 06:19 AM
