Leaded gas, will it harm anything other then your cat?
HT Black Ops
Will leaded gas damage any of your engine parts if you use it in a car designed for unleaded gas?
Re: Leaded gas, will it harm anything other then your cat? (jdmcrx34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcrx34 »</TD></TR><TR><TD CLASS="quote">i think it could also damage the o2 sensor.</TD></TR></TABLE>
yep.
yep.
Re: Leaded gas, will it harm anything other then your cat? (notstock93)
There's an awesome article in Import Tuner Issue #067 by Scott Tsuneishi titled Tell the Truth: 2NR Reveals Some Astounding Facts The Gasoline Conglomerate Doesn't Want You to Know. Sounds like a cheesy title, but its actually really interesting. The author collects and reports on the analysis of some 7 high octane California gases. He also comments on the hi-octane boosters available (which are leaded -- anything over 100 octane).
Anyway, from the article that starts on page 50 there is a section called The damaging effects of using leaded fuel. It follows "The octane readings of unleaded gasoline are capped at 100-octane. Higher-octane fuels contain lead. Tetra-ethyl lead (TEL) is one of the main ingredients added to fuel to boost octane. TEL is a very toxic material. Lead-based gasoline was eliminated from U.S. street mixtures on January 1, 1996 (January 1, 1992 in California.) The following year, cars were introduced with the first generation of catalytic converters. Before you attempt to pump your vehicle with some high-octane, leaded gas, take note that the lead content causes damage to a vehicle's catalytic converter and will slowly poson the oxygen sensors. Leaded gasolines still exist, but they marketed for sactioned, off-highway events only."
Hope this helps.. check out the rest of the article too!
HT Black Ops
Re: Leaded gas, will it harm anything other then your cat? (jlsmi2)
great post jlsmi2, just what I wanted to hear......This entire question was raised in a AIM convo I was having last night....
KeyserSoze
03-27-2006 07:22 PM
bmw626
31
06-05-2005 04:58 AM
