Stronger Oil Pump Gear - Is it Needed?
Old Dec 2, 2004 | 04:40 AM
d.str0y's Avatar
Default Stronger Oil Pump Gear - Is it Needed?
I'll be running a sleeved b16 @ 84mm, ACT 8.8lb flywheel, and stock crank pulley. Turbo with gsr valvetrain, so i'll only be revving to right around 8k. Is it necessary or a good idea to go with an aftermarket oil pump gear. The Toda one is like $300. And i'm having some trouble locating a ProDrive gear. Any opinions would be helpful. Thanks.
Old Dec 2, 2004 | 04:59 AM
PrettyLude's Avatar
its not necessary unless your making over 450 to 500whp, the prodrive one is nice
Old Dec 2, 2004 | 05:00 AM
joshuavillasenor's Avatar
Default Re: Stronger Oil Pump Gear - Is it Needed? (onezexycrx)
Stock if fine. If your that **** about oil starvation use a accusump
http://www.accusump.com All the pros use them!!
Old Dec 2, 2004 | 05:14 AM
d.str0y's Avatar
that accusump is a nice unit no doubt, but i'm not worried about starving the system of oil, i'm worried about 0 oil presure due to a shattered oil pump gear.
I found a prodrive gear for $239.00 shipped on eBay. Anyone know where I can find one any cheaper?
Old Dec 2, 2004 | 06:15 AM
PrettyLude's Avatar
i don't think you can get any cheaper than ebay price, normally i see them go around 300 plus shipping
Old Dec 2, 2004 | 07:53 AM
d.str0y's Avatar
then the main question, is it worth the money for a 350-400 whp setup?
Old Dec 3, 2004 | 02:23 AM
sinister6's Avatar
Its not that neccessary, BUT.. if you have a oil cooler.. get it.. droping oil pressure is not good.
Old Dec 3, 2004 | 06:42 AM
v4lu3s's Avatar
RTFM
look around at the stories on here of broken pro drive oil pump gears as well before msking up your mind too.
Old Dec 3, 2004 | 12:13 PM
QUiKSR20's Avatar
Default Re: (v4lu3s)
I always thought that the shattering of oil pump gears was due to RPM
and not HP just that the pump cavitates at high RPM and causes the gear
to break being that a G-Rotor pump isnt made for that kind of RPM ( 9k + )
I could be wrong but thats what I thought damages them.
Old Dec 3, 2004 | 01:36 PM
d.str0y's Avatar
yes, i've heard that too.
I'll only be revving to like 8 maybe 8.2k so i'm sure i'll be fine because i'll be running an ITR oil pump.
Old Dec 3, 2004 | 06:06 PM
QUiKSR20's Avatar
Default Re: (onezexycrx)
All VTEC B-Series pumps are the same Actually I think all B-Series are the
same supposely the Type R runs a little more pressure due to a diff spring
anyone care to comment on this?
Old Dec 7, 2004 | 02:26 PM
d.str0y's Avatar
So are they the same?
Old Dec 7, 2004 | 02:29 PM
Kataku2K3's Avatar
Most late model B series oil pumps are the same (ie they have the same gear) but I'm not positive about their spring pressure rates. We always use the ProDrive/Circuitwork oil pump gear on our high reving turbo motors and have never had a problem. What dampener are you running?
Old Dec 7, 2004 | 02:38 PM
d.str0y's Avatar
stock b16a crank pulley and on the other end an ACT ProLite 8.8lb fly. But i've heard nothing but good about the FluiDamper that endyn sells.
Old Dec 7, 2004 | 02:48 PM
Kataku2K3's Avatar
Yea the fluidamper is a nice piece if you wanna spend the money but we've never had a problem with stock even up at 10k rpm and 700whp+. You should be just fine tho especially with an aftermarket gear.
mouab18c1
Jun 14, 2013 02:11 AM
mouab18c1
Jun 12, 2013 09:56 AM
K20Ahondas
Jan 31, 2003 07:02 AM
98cwitr
Nov 25, 2002 08:31 PM
88CRXHybrid
Mar 8, 2002 02:08 PM
