HELP!!!
Old Nov 30, 2004 | 05:53 PM
cvchb91's Avatar
Default HELP!!!
i went to change my ecu in my dohc zc today and when i put the new one in it wouldnt work....i reset it and everything but it still wouldnt work so i put the old one back in and it wouldnt work either.....there is no spark coming from the distributor so could that have just went bad then???? i need some advice.....thanks.
Old Nov 30, 2004 | 05:56 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: HELP!!! (cvchb91)
Ive seen it happen before. Ive been told that it happens because the "new" ECUs circuit was shorted previously causing one of the sensors in the dist to take a crap........or you didnt disconnect the negative terminal while switching ECUs and somehow shorted it that way. Sucks man.
Old Nov 30, 2004 | 06:02 PM
cvchb91's Avatar
Default Re: HELP!!! (1320project.com)
so do you think that a new distributor would solve the problem because the old one was all messed up anyway?????? could anything else be wrong for it not to start up???
Old Nov 30, 2004 | 06:05 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Try to check all the fuses too. Its possible that sometime in the ECU swap one blew.
Old Nov 30, 2004 | 06:08 PM
dohcter g's Avatar
NEVER change an ECU with Battery terminal connected!!
Old Nov 30, 2004 | 06:10 PM
cvchb91's Avatar
what happens if the terminal is connected??? what do i need to do to fix it or what do i need to buy? if anyone has AIM, IM on icantpassenglish.....thanks
Old Nov 30, 2004 | 06:33 PM
dohcter g's Avatar
I could damage the ECU!!! If you just blow a fuse you are lucky. Just don't do it!!!
90civic-ZC
20
Oct 29, 2011 07:57 PM
allmotor-B
Engine Management and Tuning
12
Aug 29, 2011 04:21 PM
cvchb91
Dec 1, 2004 10:08 AM
simplypinoyy
Oct 14, 2004 07:09 AM
Tariqasi
Jul 29, 2003 05:09 PM
