SOHC Compression Gurus, Who Knows There Stuff
Old Dec 5, 2004 | 01:58 PM
1 Cam Wonder's Avatar
Default SOHC Compression Gurus, Who Knows There Stuff
Im hoping for someone to give me a compression ratio.
This will decide for me whether or not I go 16 pounds of boost or a 150 shot.
Setup:
A6 head, milled .040
A6 block with SRP 9.5:1 pistons
Now, I think I really want to go with boost, but feel my compression may be to high
If anyone could help me out on what headgaskets are available, the cheaper the better as I know people blow them quite a bit, but the more I can lower the compression safely will help me, I also have aftermarket head studs
I am limited to 93 octane and this will be my first F/I setup, if the comrpession is to high for DD on pump gas then Im just gonna go ahead and spray a direct port 150, cheaper, probably faster in the 1/4 but wont always be there
Hard decision, LMK
Thanks
Old Dec 5, 2004 | 03:50 PM
Default Re: SOHC Compression Gurus, Who Knows There Stuff (1 Cam Wonder)
Old Dec 7, 2004 | 12:02 PM
builthatch's Avatar
MiG-21 superfan
Were the pistons designed with the a6 combustion chamber in mind? Are they specifically for an a6? If so, then you figure the .040 mill will add about .7-8 points to the c/r of 9.5:1...if the pistons are not specifically for an a6, then there is no way to tell without measuring.
I am assuming this block is sleeved; what turbo, what rods are you running and what engine management?
I think turbo is the way to go, but-
If you are not concerned about it always being there, then it might be a good idea to juice it; spend the money on a fuel cell and associated parts, and go with the nitrous...it will be waay cheaper than the turbo kit, you can sell those 9.5:1 and get some higher comp. pistons. This way the engine will be pretty peppy off the bottle. The higher the compression, the better it will react with race fuel and juice and the faster you go.
meanshyguy
15
Mar 21, 2008 03:00 PM
memorybox
Sep 25, 2006 06:28 PM
DeadVet
Feb 9, 2005 12:34 PM
booscivic
Nov 12, 2003 06:17 AM
90da4dr
Mar 9, 2003 05:18 AM
