After market lsd clicking.
Old Nov 30, 2004 | 06:00 PM
Gsr_Rob's Avatar
Default After market lsd clicking.
Took apart my friends itr tranny and it has an ats or spoon diff. The car made a clicking noise will turning at all speeds. At lower speeds it felt like the alxes were slipping, like jumping the teeth on the slpines. We replaced the axles with new aftermarket and new oem axles. We also changed the halfshaft(midshaft). Is the Diff the only thing that could be messed up. Tranny shifted fine and the car launched fine. Any help would be appreciated. Thanks ROB
Modified by Gsr_Rob at 9:25 PM 11/30/2004
Old Nov 30, 2004 | 10:00 PM
mtber's Avatar
mscoastracing.com kicks ***!
Old Dec 1, 2004 | 02:15 AM
vteczone's Avatar
Default Re: After market lsd clicking. (Gsr_Rob)
try different lubrication..what lubrication r u using?
Old Dec 1, 2004 | 07:51 AM
Gsr_Rob's Avatar
We were using castrol 10w 30. Thanks mtber
Old Dec 1, 2004 | 07:56 AM
vteczone's Avatar
hmmm..i use that too. but i was told to use proper lubs if u get noise from the lsd..
Old Dec 1, 2004 | 08:39 PM
Gsr_Rob's Avatar
Default Re: (vteczone)
I may have been mislead but I was told that a 1.5 way would click/make noise while turning. I have been reading up on lsds and I haven't read anything about noises while turning. I don't know I'd feel bad if its the tranny and not the lsd. He already bought a quaife and its about to go in. I don't think an aftermarket lsd like spoon or ats would make noises like that. But you never know. We didn't try changing fluid types. Anyway someone get back to me about a 1.5 way make any noise.
Old Dec 4, 2004 | 12:24 AM
cxSOHChatch's Avatar
Default Re: (Gsr_Rob)
i have a kaaz lsd and i use the kaaz 80w-90 oil. it clicks also, even more when i had honda transmission fluid.
a few shops have confirmed that the clicking sound is normal, so im not concerned.
Old Dec 4, 2004 | 06:11 AM
atcrx's Avatar
Default Re: (cxSOHChatch)
The clicking noise you hear is the clutch in the LSD slipping. when turning one wheel turns faster than the other. so the lsd is put in a bind of sorts. so the thing that has to give is the clutchs in the lsd. GM offers a limited slip additive for their lsd's it will work in anything. we put it in auto transmissions that have torque converter shudder. try that additive along with the recommended fluid and it will probably quieten down the lsd tremendously.
Old Dec 4, 2004 | 03:07 PM
doublejz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSOHChatch &raquo;</TD></TR><TR><TD CLASS="quote">i have a kaaz lsd and i use the kaaz 80w-90 oil. it clicks also, even more when i had honda transmission fluid.
a few shops have confirmed that the clicking sound is normal, so im not concerned.</TD></TR></TABLE>
well its not really normal, either
1. Out of align
2. Clutches weren't broken in properly
3. Clutches are worn in the diff
4. Wrong fluid - Kaaz fluid has special additives
Old Dec 7, 2004 | 09:28 AM
Gsr_Rob's Avatar
Default Re: (doublejz)
it is horrible when you are starting out like from a stop sign turning left or right. the car kinda jerks around, like a bad cv axle.
Old Dec 9, 2004 | 04:25 PM
doublejz's Avatar
get your alignment checked
Old Dec 11, 2004 | 10:36 AM
supertran25's Avatar
Default Re: (atcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atcrx &raquo;</TD></TR><TR><TD CLASS="quote">. when turning one wheel turns faster than the other. so the lsd is put in a bind of sorts. so the thing that has to give is the clutchs in the lsd. . </TD></TR></TABLE> I could be mistaken but a car without lsd puts more power to one wheel. I thought the job of the lsd was to distribute power to the wheels evenly.
Old Dec 24, 2004 | 07:00 AM
doublejz's Avatar
Default Re: (supertran25)
you are correct the lsd is suppose to distribute the power to both sides. However about the clutches slipping when one wheel is turning faster then the other, isn't all true. I know when I make sharp turns from a stop (and the lsd is working correctly, car aligned, etc.) the inner tire chirps throughout the turn, therefore not being the clutches slipping.
redline870
Dec 3, 2008 11:21 AM
ITR_HO
Feb 9, 2007 03:02 PM
one^g
14
Nov 14, 2005 12:31 PM
chambersef8
Apr 1, 2004 06:03 PM
JDM97R
11
Jan 23, 2004 01:17 PM
