which is the clutch master cylinder
i know where it is but im confused between the big and little reservior, mine just gave out and i've been looking where my pedals are and i see the brake fluid, from my point of view it looks like its connected to the big reservior thingy thats on that black circle plate looking thing, am i correct, just want to make sure before i go buy the part and and fix it myself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BumpinVTEC »</TD></TR><TR><TD CLASS="quote">the big reservior thingy thats on that black circle plate looking thing</TD></TR></TABLE>
Are you sure you want to do this yourself? It kinda sounds like you might need someone there to help you.
Master cylinder = brakes (big "thing")
Slave cylinder = clutch (little "thing")
If you are doing a mc install make sure you bench bleed it!! That's imperative
thanks for the info and yes i do know what there called i was just to lazy to type out the full name for each part, i know i got to bleed them so i just made a bleeder kit out of a water bottle
"the big reservior thingy thats on that black circle plate looking thing"
"brake master cylinder"
I'm lazy and I choose the shorter way.
vtecdc2
May 20, 2003 07:27 AM
