installing pistons check list.....
Old Dec 4, 2004 | 11:41 AM
SHystrdyGSRtdy's Avatar
Default installing pistons check list.....
if this was for a gsr motor.... please let me know if this check list is complete
4- pr3 pistons + rings
1- headgasket
1- waterpump
1- oilpump
1- oil pan gasket
1- cam seal
1- set of arp headstuds
1- timing belt
which rod bearings would i have to get?
what about rod studs?
Old Dec 4, 2004 | 11:56 AM
boosted k20's Avatar
Default Re: installing pistons check list..... (SHystrdyGSRtdy)
im do n PR3 in my LS block as well. im get n a set of ACL rod bearings from honda-tech user Earl for $50. good price!
get arp rod bolts. im not gonna get rod bolts for my LS cuz i dont plan on rev n past 7K's
also u will need to take the old rods and pistons to a machine shop to have them press the old pistons out of the rod and install the new ones.
question, do u really need to change the oil pan gasket or can u just reuse the old one and put some honda bond around it?
Old Dec 4, 2004 | 02:58 PM
drdisco69's Avatar
Default Re: installing pistons check list..... (boosted k20)
I'd use a new gasket unless the one on there has less than like 20k miles. It's only a few dollars, nothing compared to what you already spent.
Don't forget your valve cover gasket, and maybe a distributor o ring and spark plug grommets if it needs them.
mcgee*
Jan 7, 2007 08:05 PM
mcgee*
Jan 6, 2007 08:40 AM
J.nguyen
Jun 13, 2006 07:41 PM
STHPERFORMANCE
Nov 1, 2002 08:13 AM
HX_Guy
Nov 15, 2001 12:39 PM
