Exhaust Manifold
Old Dec 1, 2004 | 02:52 PM
waltersr's Avatar
Default Exhaust Manifold
I have a 98 Civic lx my exhaust manifold cracked i brought to where i bought it from and they are telling that a new one is going to cost $400. Also he told that this is going to keep cracking after i replace it. I was wondering if anyone knew anything about this.
Old Dec 1, 2004 | 02:57 PM
drdisco69's Avatar
Default Re: Exhaust Manifold (waltersr)
How many miles are on the car?
Old Dec 1, 2004 | 03:03 PM
waltersr's Avatar
Default Re: Exhaust Manifold (drdisco69)
it has 98000 miles
Old Dec 1, 2004 | 03:14 PM
mattssi's Avatar
It shouldn't be cracking, is there some aftermarket exhaust on there that is pulling on the stock mani or something? The cast mani should outlast the car? Something about it isn't right
Old Dec 1, 2004 | 03:17 PM
waltersr's Avatar
Default Re: (mattssi)
Everything on the car is stock apartely the mechanic working on it called a honda dealer and they said i was a design flaw. i dont know if that is relyable info.
Old Dec 1, 2004 | 03:22 PM
civic-4-ges's Avatar
Default Re: (waltersr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waltersr &raquo;</TD></TR><TR><TD CLASS="quote">Everything on the car is stock apartely the mechanic working on it called a honda dealer and they said i was a design flaw. i dont know if that is relyable info.</TD></TR></TABLE>
It is, and it a very common problem, it happened to me too.
Best bet is to get an aftermarket cat and an exhaust manifold from a vtec engine of the same body style.
Old Dec 1, 2004 | 03:27 PM
waltersr's Avatar
Default Re: (civic-4-ges)
What kind of aftermarket cats are good
Old Dec 1, 2004 | 03:28 PM
drdisco69's Avatar
Well I work at a honda dealer, so I'll tell you whats up. The civic manifolds with the integrated catalytic converter have a problem with cracking. It usually starts around the oxygen sensor at the top, and runs from the front to the back over the top between cylinders 2 and 3. Since the catalytic convertor is build into the manifold, it's covered under the 80,000 mile, 8 year federal emmisions warranty. Unfortunately you're out of the coverage period, so it might be time to start spending a little money.
Old Dec 1, 2004 | 03:32 PM
mattssi's Avatar
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Well I work at a honda dealer, so I'll tell you whats up. The civic manifolds with the integrated catalytic converter have a problem with cracking. It usually starts around the oxygen sensor at the top, and runs from the front to the back over the top between cylinders 2 and 3. Since the catalytic convertor is build into the manifold, it's covered under the 80,000 mile, 8 year federal emmisions warranty. Unfortunately you're out of the coverage period, so it might be time to start spending a little money.</TD></TR></TABLE>
I forgot about those.... Thats right, I remeber hearing about those. I would change that out. Get a differen't sohc mani and get a older(but new)style cat and use that setup.
Old Dec 1, 2004 | 03:36 PM
drdisco69's Avatar
Cat, what cat?
Old Dec 1, 2004 | 03:43 PM
waltersr's Avatar
is there any way i could get a full exhuast system if so what kind i know it needs 2 oxygen sensors. What model car shlould i get the manifold off of?
g075m0k3d
Aug 8, 2008 05:41 AM
Lithel
Feb 26, 2008 03:25 PM
EL Vap133
23
May 6, 2005 04:54 PM
Ek9Max
10
May 23, 2004 09:13 AM
