need some help
Old Dec 1, 2004 | 09:11 AM
cvchb91's Avatar
Default need some help
i just swapped ecus in my dohc zc and it wouldnt start, i reset it and everything but the distributor isnt giving any spark, so im getting a new one cause the old one was coroded anyway and i was just wondering if that doesnt solve the problem, what else might it be????
Old Dec 1, 2004 | 10:08 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: need some help (cvchb91)
Check your grounds. Check them at the ECU first. If you have a computer safe test light, figure out which wires coming off the ECU go to ground.. if they read positive when the key is in the run position, you have a bad ground someplace. Otherwise, im guessing bad ECU.
b17 turbo
May 7, 2008 11:28 PM
cvchb91
Nov 30, 2004 06:33 PM
89hatchback
Feb 13, 2004 07:05 PM
sailor
Mar 28, 2003 08:38 PM
